Simulate screws
Hi, I am new in FEA modelling, I am trying to study Code Aster and I am stucked on screws… I spent hours trying to get some results with AI assistants, but without success… I just want to connect two solids with screws, apply some pretension, friction on contact planes but I think I am missing something… I am using two solid parts with holes and four screws created just like cylinders with thicker cylinders on both ends, but Code Aster is always giving me new errors… I was not even able to find some tutorial for this kind of contact… please, can you help me? Thanks
I’m not sure if I can help, but to give it a try, we would need more information. E.g., share your .comm and .med file, a sketch/screenshot of the geometry, your modeling approach (do you model the screw as 3D geometry, or do you use a simplification like beam elements), what you tried so far, error messages you are encountering, …
So far I can only give you one general recommendation: start with a simple model. Don’t start with friction contact; start with bonded contact. So far I can’t tell where exactly you want to have frictional contact but maybe also start with a simpler model with only the contact and without other interactions.
