salome-meca for windows Error: Can not save file
Dear Sir,
eh installed salome-meca for windows, operating system windows 10 64 bits, I have the following error when trying to save:
Error is
Can not save file “/home/user/User/Gerardo/Desktop/study1.hdf”
possible reasons:
-permission denied;
-unsufficient disk space;
-application error.
I will appreciate your help.
Best regards,
Gerardo Rojas
This may sometimes happen with SALOME. Check that:
[list=*]
you’re not using special characters or blanks in the path of the HDF study or the files used inside it;
you have enough free space left, notably in /tmp.
[/list]
TdS
i have 60 gb space in my disk but unable to save please help me out
I cant save the files in windows neither.
I need help with this problem too.
Could someone tell us what is going on?
Hello alltogether,
I’m facing the same problems in salome-meca 2018 for windows. There’s enough diskspaceand I also checked the permissions. Is there any quick workaround to be able saving files ?
I would highly appreciate any quick help, as I’m using it very often in Liinux system, but I have windows on my portable computer.
Thank you,
Jan
I have been facing the exactly same problem as Gerardo, using Windows 10 64bits:
Can not save file “/(…).hdf”
possible reasons:
-permission denied;
-application error.
I noticed that this problem start happening when the simulation becomes bigger, requiring more disk space, however I have plenty of disk space!
Does anyone have a guess on how to solve this?
Thanks
the problem is well known and explained in the post “Salome-Meca 2019 for Windows” in the site of Code_Aster for Windows. You must remove the “read only” flag of the files before saving them.
It is a Salome issue:
www salome-platform.org/forum/forum_10/520839533
Konyaro
The post on “Code Aster for Windows” website seems to cover a different kind of error…
Anyway, I tried to uncheck the “read only” flag from the file, but the error persists :frowning:
:>The post on “Code Aster for Windows” website seems to cover a different kind of error…
Have you unchecked the “read only” flag both on the hdf file and the _Files Folder and its contents?
Have you found a solution? Because you were right, I have the same problem now, even when I uncheck read only.
Any news on this issue? Has the solution been posted somewhere else within this forum? Thanks anyway!
Serge
Have a look at:
www. salome-platform.org/forum/forum_10/541818275
Many thanks for the information. The proposed solution works :slight_smile: !
Dear Sir,
i have installed salome-meca for windows, operating system windows 10 64 bits, I have the following error when trying to save:
Error is
possible reasons:
-permission denied;
-application error.
Something to try:
Filename/path like “/home/user/User/Gerardo/Desktop/study1.hdf” is not a valid Windows path. Try another name.
Other reasons for not being able to write to the hdf file can be that a phantom server process is rendering the .hdf file R/O. In that case, save in a different name and afterwards shutdown the session server use the kill_salome.bat command (in the distribution directory).
I could not find this post: www. salome-platform.org/forum/forum_10/541818275. I am too facing similar issues discussed here and I have tried all the solutions suggested except what is the post 10/541818275, which I couldn’t find.
Much appreciate your help.
Not sure if this will be helpful to anymore. Try increasing the tmp fs size from 2GB to say something like 20GB
try:
sudo vi /etc/fstab
tmpfs /tmp tmpfs defaults,size=20G 0 0
Thanks for your suggestion. However, the error still pops up in between. I sigh and then close the program, refresh couple of times or restart computer and proceeds from my last saved file! Now I kind of expect this to happen, so not greatly disturbed since I save my file after every modification.
