RBE3 on isolated node
Dear all, I’m quite new to code-aster and in I’m working with Salome Meca 9.13, Code Aster 17.4 on Windows11.
I’m trying to understand the right procedure to apply a BC on a node connected to che main mesh with a RBE3 element.
Something like below image:
[upl-image-preview uuid=a9a89735-59f2-49b1-a37d-d39a1e39a1e4 url=
alt={TEXT?}]
Which component shoud I create on Mesh (or geometry) and which one on AsterStudy
By now I was creating a 3D beam on geometry, with groups of 3D, Fix Face and RBE3 face (Load Face).
Then in mesh I get groups from geometry and create an additional node in front of RBE3 face 10mm away, with his group and 0D element on it (Load_Point and 0D_Load).
Ottengo un errore di singolarità della mesh
mesh = LIRE_MAILLAGE(FORMAT=‘MED’,
                 UNITE=20)
model = AFFE_MODELE(AFFE=(_F(GROUP_MA=(‘Load_Face’, ‘Fix_Face’, ‘Beam’),
                         MODELISATION='3D',
                         PHENOMENE='MECANIQUE'),
                      _F(GROUP_MA=('0D_Load', ),
                         MODELISATION='DIS_TR',
                         PHENOMENE='MECANIQUE')),
                MAILLAGE=mesh)
elemprop = AFFE_CARA_ELEM(DISCRET=_F(CARA=‘K_TR_D_N’,
                                 REPERE='GLOBAL',
                                 VALE=(1000000000.0, 1000000000.0, 1000000000.0, 1000000000.0, 1000000000.0, 1000000000.0)),
                      MODELE=model)
steel = DEFI_MATERIAU(ELAS=_F(E=210000.0,
                          NU=0.3))
fieldmat = AFFE_MATERIAU(AFFE=_F(MATER=(steel, ),
                             TOUT='OUI'),
                     MAILLAGE=mesh)
load = AFFE_CHAR_MECA(DDL_IMPO=_F(DX=0.0,
                              DY=0.0,
                              DZ=0.0,
                              GROUP_NO=('Fix_Face', )),
                  FORCE_NODALE=_F(FX=1000.0,
                                  GROUP_NO=('Load_Point', )),
                  LIAISON_RBE3=_F(COEF_ESCL=(1.0, ),
                                  DDL_ESCL=('DX-DY-DZ' ),
                                  DDL_MAIT=('DX', 'DY', 'DZ'),
                                  GROUP_NO_ESCL=('Load_Face', ),
                                  GROUP_NO_MAIT=('Load_Point', )),
                  MODELE=model)
reslin = MECA_STATIQUE(CARA_ELEM=elemprop,
                   CHAM_MATER=fieldmat,
                   MODELE=model,
                   OPTION='SIEF_ELGA')
reslin = CALC_CHAMP(reuse=reslin,
                CONTRAINTE=('SIGM_NOEU', ),
                FORCE=('REAC_NODA', ),
                RESULTAT=reslin)
IMPR_RESU(FORMAT=‘MED’,
      RESU=_F(MAILLAGE=mesh,
              NOM_CHAM=('SIGM_NOEU', 'DEPL', 'REAC_NODA'),
              RESULTAT=reslin),
      UNITE=80)
@mastraa
before discussing the way to handle an RBE3 i see in your .comm file
MODELE=model,
OPTION='SIEF_ELGA')
for it to work there should be at least a section like this
EXCIT=(
	 _F(CHARGE=load,),
and it is a very bad idea to mix up in a single AFFE_CHAR_MECA
DDL_IMPO that is boundary condition
FORCE_NODALE or all loads
LIAISON_RBE3 or any internal links of this type
use 3 AFFE_CHAR_MECA in your case
then with
with such a high stiffness on the point element whatever the units are i doubt it will allow physical meaningful displacement
Ok, after several attempts where I surely made mistake with coupling DIS_T/TR with K_T_D_N…I finally prepared the right RBE definition and made a newbie mistake…
Thank you, the EXCIT was the issue this time.
About other suggestion you’re right, not the best way and I will improve the comm. Anyway it works.
Thank you!
Regarding stifness I found out something I cannot explain.
I follow your suggestion to reduce 0D element stiffness.
With 210.000.000 Total reaction on Fix face i 10N
reducing to 210.000 (same as my material): 5000N
21.000: 9000N
1.0: 9999N
0.1 or 0.0: 10000N
Why this happens?
In any case stress component on X direction is 100MPa (=F/A=10000/(10*10))
Here my estraction operation
reac = POST_RELEVE_T(
ACTION=_F(
GROUP_NO=('Fix_Face', ),
INTITULE='REACTION',
NOM_CHAM='REAC_NODA',
OPERATION=('EXTRACTION', ),
RESULTANTE=('DX', ),
RESULTAT=reslin
EDIT: It was not a newbie mistake. I figured out that if you try to modify MECA_STATIQUE field in AsterStudy sometimes (or always I can’t say) it remove EXCIT option from the definition.
Probably in these days I already tested the right .comm file but while I was updating MECA_STATIQUE it removes EXCIT and the errors came from that. Be careful.
It happens once more with a file that works before so I check on MECA_STATIQUE (the only updated sentence) and figured out.
@mastraa
[quote
21.000: 9000N
1.0: 9999N
0.1 or 0.0: 10000N
[/quote]
try to be clearer
i do not understand what you mean
i the case depicted by the picture the right value for the stiffness in the load direction is obviously null or almost null
Ok, at the end of my experiment I figured out the same. K should be null.
I don’t grasp the the theory behind…
I mean: I thought the stiffness was the the stiffness of ideal beam/spring connecting nodes of 0D to face ones.
With my ‘experiment’ I got correct stress along force direction for every stiffness set.
But fixed face reaction results in 10.000N (as expected) only when stiffness was around 0. And I can’t understand why
@mastraa
it is just basic theory of elasticity elasticity
a VALE of 1000000000.0 for a translation DOF on a OD element means that a force of 1000000000.0=1E9 unit of force will move the point 1 unit of length
then the stress will be calculated from these displacements
@jeanpierreaubry
Thank you, now I understand what this stiffness means!
I thought it was stiffness of 0D to structure connection, not 0D to the ground.
Ansys permuta to define it rigid, deformable or ‘beam’ so I thought it was like this ‘beam’…
Now it’s clear, very thank you
