Hi, I just setup a virtual machine running on a Xen 6.5 server to which I connect via xrdp.
Host is Linux Mint 22.2 which is based on Ubuntu 24.04.3 (Noble Numbat).
Singularity container is “salome_meca-lgpl-2024.1.0-1-20240327”
Geometry module window works, Mesh module window works but when I activate the ParaView module Salome-Meca crashes.
In the starting terminal I get a warning that I should start salome-meca in mesa version but the program starts anyway. Further it isn’t described how to actually start in mesa mode. I tried the --soft flag but the issue is the same.
Anybody else experience something like this ? And if so, did you find a solution ?
Thanks for reading and commenting.
