running salome_meca-lgpl-2024.1.0-1-20240327 on Ubuntu 24.04.2 LTS.
I get sigsegv error whenever I try to open geometry, build..
Error message:
*** Abort *** an exception was raised, but no catch was found.
... The exception is:SIGSEGV 'segmentation violation' detected. Address 58000418
... The exception is:SIGSEGV 'segmentation violation' detected. Address 8
omniORB: (?) 2025-03-27 11:49:52.928110: Assertion failed. This indicates a bug in the application
using omniORB, or maybe in omniORB itself.
file: /volatile/projet/salome/jenkins/workspace/SALOMEBuilder/SALOME-9.12.0-native-DB11/SOURCES/omniORB/src/lib/omniORB/orbcore/current.cc
line: 139
info: !pd_callDescriptor
terminate called after throwing an instance of 'omniORB::fatalException
Kind regards,
Roger
Good afternoon,
I reinstalled Salome_Meca and now I get the following errors:
roger:~/Salome_Meca$ ./salome_meca-lgpl-2024.1.0-1-20240327-scibian-11
/home/roger/Salome_Meca/./salome_meca-lgpl-2024.1.0-1-20240327-scibian-11:433: SyntaxWarning: invalid escape sequence ‘.’
regexp = re.compile(“hwloc_(.*).so”)
- running salome_meca in GPU mode
++ using container salome_meca-lgpl-2024.1.0-1-20240327-scibian-11.sif
++ prepend system ‘libGL*’ libs
** (SALOME_Session_Server_No_Server:28982): WARNING **: 15:28:44.011: atk-bridge: get_device_events_reply: unknown signature
double free or corruption (out)
All this happens since I reinstalled Ubuntu and restored the home directory from backup.
Roger
This seems to be (in my case anyway) a problem related to the fact that I have two video-cards, one intel the other NVIDIA.
I went to NVIDIA settings and changed in PRIME Profiles to NVIDIA(Performance Mode) .
Problem solved.
Further info : [How to Install & Use NVIDIA Driver in Ubuntu 24.04 | 22.04 | UbuntuHandbook]
Roger
