Where can I access old style pdf documents of code_aster? The new documentation is still not perfect and I would like to access old ones.
Regards
Anirudh
Regards
Anirudh
I add myself to this request. Also, theoretically it should be possible to select in https://codeaster.gitlab.io/doc/docaster/manuals/man_u/other_pages/home/index.html the version but I cannot see anything but version 18. How can I access previous versions of the documentation?
Thank you and best regards,
Corrado
Yes, old documentation (English, pdf version) is an urgent necessity. I would like to ask the developer/admin to provide at least a temporary site to enable downloading in previous format.
I tried to compile the documents from the repository also. But that failed as the config tried and failed to access some singularity container.
Thanks and Regards
The EN web version from last year still works, if that helps?
Le code est français, il faut apprendre la langue !
All pdf docs from older versions removed from documentation page?
Regards
Hello, old documentation is available here https://code-aster.org/doc/v16/
