is it possible to create cham_no type of data from a numpy array ?
Is it possible to do the same for matrices, create one from sparse datas ? (Because of element dependancy, I primarly think no, but why not.)
If not, how to add rows and columns to an existing aster matrix ? Add rows to an existing aster vector ?
The idea is to solve a linear problem with large amount of dofs. It would be better to do it inside aster rather than scipy I think.
I dig a bit in the subject.
I am able to modify an existing cham_no like
PHI = CREA_CHAMP(NOM_CHAM='DEPL',
NUME_MODE=1,
OPERATION='EXTR',
RESULTAT=modes,
TYPE_CHAM='NOEU_DEPL_R')
PHI2 = PHI
PHI2.setValues(list_of_vals)
How to create one from nothing ?
In the help of libaster there is the initialisation of FieldOnNodesReal
def __init__(self, *args, **kwargs):
"""Overloaded function.
1. __init__(self: libaster.FieldOnNodesReal) -> None
2. __init__(self: libaster.FieldOnNodesReal, arg0: libaster.FieldOnNodesReal) -> None
3. __init__(self: libaster.FieldOnNodesReal, arg0: Model) -> None
4. __init__(self: libaster.FieldOnNodesReal, arg0: libaster.BaseDOFNumbering) -> None
5. __init__(self: libaster.FieldOnNodesReal, arg0: libaster.EquationNumbering) -> None
6. __init__(self: libaster.FieldOnNodesReal, arg0: tuple) -> None
7. __init__(self: libaster.FieldOnNodesReal, mesh: libaster.BaseMesh, quantity: str, cmps: list[str]) -> None
8. __init__(self: libaster.FieldOnNodesReal, mesh: libaster.BaseMesh, quantity: str, values: dict[str, float], groupsOfNodes: list[str] = [], groupsOfCells: list[str] = []) -> None
I don’t know what are the lasts inputs in 7 and 8 (mesh is ok I think, from LIRE_MAILLAGE).
Anyone ?
The 8th options seems the most adapted but I don’t know how to fill it.
I do
import code_aster
A = code_aster.Objects.FieldOnNodesReal(mesh, 'DEPL_R')
but I don’t know how to build the dict asked. The str is the componant, so I would say ‘DX’, ‘DY’ and ‘DZ’, but you cannot have repeated keys in the dict so i don’t know how to do this…
With the 7. :
import numpy as np
import code_aster
A = code_aster.Objects.FieldOnNodesReal(mesh, 'DEPL_R', ['DX', 'DY', 'DZ'])
A.setValues(phi.tolist())
