In new version are new interesting operators, “MECA_NON_LINE” and “DEFI_CONT”.
I have compiled from Gitlab version 17.4.18 and it works, except it gives error “DEFI_CONT” not found.
My question, is something other commands needed to activate “DEFI_CONT”.
In source code I found it from /MacroCommands directory, but was missing from /Cata/Commands and /CodeCommands directories.
Messages from solver: "
KONTTI = DEFI_CONT(MODELE=MALLI,
NameError: name ‘DEFI_CONT’ is not defined
Traceback (most recent call last):
File “”, line 198, in _run_module_as_main
File “”, line 88, in _run_code
File “/opt/aster/install/20251026/gcc12-openblas-ompi4/mpi4py-3.1.6/lib/python3.11/site-packages/mpi4py/main.py”, line 7, in
main()
File “/opt/aster/install/20251026/gcc12-openblas-ompi4/mpi4py-3.1.6/lib/python3.11/site-packages/mpi4py/run.py”, line 230, in main
run_command_line(args)
File “/opt/aster/install/20251026/gcc12-openblas-ompi4/mpi4py-3.1.6/lib/python3.11/site-packages/mpi4py/run.py”, line 47, in run_command_line
run_path(sys.argv[0], run_name='__main__')
File “”, line 291, in run_path
File “”, line 98, in _run_module_code
File “Test_2.comm.changed.py”, line 84, in
NameError: name ‘DEFI_CONT’ is not defined. Did you mean: ‘DEFI_CONTACT’?
I repeat, in V17 documentation is this DEFI_CONT, but my compiled from GitLab I receive this error.
Best Regards
Ilkka
