Hunderds of error report in terminal
I put this formula for offset which I want to use with DIST_MAIT = offset under DEFI_CONTACT
offset = FORMULE(NOM_PARA=(‘INST’),
              VALE='0.0005-(INST-1)*0.0005',
So, the offset is a function of time which gradaully becomes zero starting from some value.
However, I got hundreds of error report in terminal like this:
[upl-image-preview uuid=5ceaa579-535d-450b-bc85-3a81344ae105 url=
alt={TEXT?}]
Is there something wrong with this Formula and why did I get so many reportbacks in terminal?
Regards
Anirudh
Hello @vishwas
Could you provide a test case that reproduces this bug?
I’ll try if possible.
Regards
I did some test again and found that I misspelled INST to IMST under formula keyword :
offset = FORMULE(NOM_PARA=(‘IMST’),
              VALE='0.001-(IMST-1)*0.001',
This ofcourse is an error on user side. But the software keep reporting the error(in a unreadable manner)
No matter what the error is, the software should come to a stop and release system resources like processors.
Here in this case I had to press CTRL+C to physically interrupt code_aster run as this error keep coming up. I attach the log output. This is a multi stage analysis. The error is observed duiring POURSUITE() stage2.comm.
files attached here:Dropbox
Regards
Anirudh
HEllo,
There is no simple, straightforward way to cleanly terminate a multi-processor computation with MPI
