Hello everyone,
I am seeking help to resolve an issue where AsterStudy cannot detect or populate the Code_Aster solver versions in my local setup, preventing me from running any analysis.
My System Information:
OS: Ubuntu 22.04.5 LTS
Container Manager: Apptainer version 1.5.3
Salome-Meca Image: salome_meca-lgpl-2025.1.0-1-20251026-scibian-12.sif
AsterStudy Version: 2025.1.0 (verified via Help > About)
Problem Description:
After fully setting up my mesh and study parameters in AsterStudy, I go to the “History View” to execute the case. In the “Run parameters” section at the bottom:
The Run servers dropdown shows localhost.
The Version of code_aster dropdown is completely empty. It does not show stable, 2025, or any other option.
Because this field is blank, when I try to run the study, I receive the following error:
“No available version found on localhost, previous serve is selected”
Immediately after this, the application fails or crashes.
What I have tried:
I checked the configuration by going to Tools > Preferences > AsterStudy. The “Version of code_aster” setting is currently set to “Use default”. If I click this dropdown, there are no other versions listed to select. I have also tried restarting the container, but the issue persists.
It seems the GUI is unable to communicate with the solver backend inside the container. Has anyone encountered this issue with the 2025.1.0 Apptainer image? How can I properly configure the localhost server or populate the solver versions so I can run my simulations?
