3D-Beam visualisation in asterstudy
i want to share a plugin for salome that visualizes the section in the 3D-view of asterstudy with a click of a buttin. Rectangle and circular sections are rendered directly, general sections are rendered with elliptical cross section of corresponding moment of inertia.
For linux put the files somewhere in your home directory and edit your .bashrc like so:
# add the following to the bottom of your .bashrc
export SALOME_PLUGINS_PATH="<PATH TO YOUR HOME>/.salome/plugins/balkenkontrolle"
Here’s the link to the repo: GitHub - larsmei/balkenkontrolle: SALOME-Plugin für AsterStudy: lokale Balkenachsen und Querschnitte aus AFFE_CARA_ELEM (Code_Aster U4.42.01). · GitHub
Excelent! Work. I hope the development of Aster-Study continues. With its current Python-based interface, its range of options can be expanded using plugins.
