#1 2023-11-20 16:05:06
k_zurawski
[SOLVED sort of]Need help with script running export file fromTerminal
During training I received from Johannes Ackva a script to run Code_Aster's export file from terminal. I got used to this way of running a simulation. The script has been written for non-singularity version of Salome_Meca. Now I'd like to change it to be able to run it for the most recent version of C_A. Could anyone help me with that?
Basically what script does is checking if there's an export file, if the export file is really an export file and if both conditions are met it copies/saves the export file under new name "the-export-file", runs it and deletes it. I'd like to leave it that way.
Salome_Meca 2022 sif file is placed in /opt/sm/
#! /bin/sh
#. /home/user/sm20/appli_V2020.0.1_universal_universal/env.d/envProducts.sh (this line I don't know how to change for singularity version, there's no  folder there)
if test $# -eq 0 ; then
       echo "!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
       echo "!!        !!"
       echo "!!      The Code-Aster start file (export) is lacking         !!"
       echo "!!        !!"
       echo "  "
       exit 1
fi
for i; do
     if test -f $i; then
       cp $i  the-export-file
        singularity exec /opt/sm/salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif salome shell -- as_run the-export-file
       rm the-export-file
     else
       echo "  "
       echo "!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
       echo "!!        !!"
       echo "!! Given argument is not a Code-Aster start file (export)    !!"
       echo "!!        !!"
       echo "  "
     fi
done
At this point I'm getting error that there's no "the-export-file" and the simulation stops. I have little to none coding experience, but for 100% second line is wrong. Is there a way to check what's folder path to envProducts.sh in singularity container?
regards,
Krzysztof
#2 2023-11-20 16:26:24
Re: [SOLVED sort of]Need help with script running export file fromTerminal
the folder/file you're searching inside the container is under
/opt/salome_meca/appli_V2022.1.0_scibian_univ/env.d
There you will find the script envProducts.sh
You can check that by starting the container via
./salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif --shell
Not sure if that will work the same way, though. You'd have to launch your script inside the container,
#3 2023-11-20 16:29:20
k_zurawski
Thank you.
Do you know what envProducts.sh is for? What it does?
regards,
Krzysztof
#4 2023-11-20 16:33:06
not particularily, in the header it says "# SALOME_MECA V2022 - Environnement file for the prerequisites and tools".
There's a lot of checking for installed prerequisites and a boatload of path definitions. So I am intended to say 'it prepares the environment for Code Aster'. I have no idea if this is true, though,
#5 2023-11-20 16:38:27
what a complicated way to do something very simple
once i have a valid export file
i just open the singularity shell
$HOME/salome_meca-lgpl-2021.1.0-1-20220405-scibian-9.sif shell
and run this command
xterm -e as_run the_export_file.export
just one trouble if the export file is not valid it may result in a crash
in fact i sandboxed the container and the opening time is divided by a factor of several tens
#6 2023-11-20 16:43:55
k_zurawski
Well, there is asbin alias setup in .bashrc to run the script. So in this case I have two advantages. In study folder I just write asbin study.export and the second is that there is no export file alteration. When I run it manually there are folder paths added to export file. So when I reuse the file I have to change more than just study filenames (med, rmed, resu, mess, comm etc.).
regards,
Krzysztof
#7 2023-11-20 16:54:07
k_zurawski
what does -e before as_run mean?
regards,
Krzysztof
#8 2023-11-20 17:01:26
xterm -e program_file
means excecute
program_file within xterm
it open an xterm window outside the singularity shell
i prefer it that way, just that
#9 2023-11-20 22:03:09
k_zurawski
Thank you
regards,
Krzysztof
#10 2023-11-21 10:37:05
k_zurawski
Jean Pierre,
Could you write step by step commands to run the simulation by running export file from terminal? But not from Xterm, just the regular one. I tried yesterday, but sadly I can't announce success...
As I said, I'm illiterate when it comes to programming, the same applies to Singularity.
Thank you in advance.
BTW can someone point me to some good training material of Singularity? I watched something on YT, but couldn't find anything helpful. Just some brief description to someone familiar with Docker etc. I'm not that guy.
regards,
Krzysztof
#11 2023-11-21 11:41:35
i am not exactly sure of what you mean
i think it is not possible from a regular linux terminal you have to go to the singularity shell
by running
and in this shell running
should do the job in the singularity shell, at least it does on my komputer
i am afraid i am just a small step above
i have been unable to find any valuable [or understandable] dokumentation about singularity
some posts in this forum helped me somehow
some by hberro, i have to thank him here
the following was just guess plus trial and error and a few head scratching!
#12 2023-11-21 12:52:10
k_zurawski
by running
So your study (export file) is in $HOME/ when you run it? Am I right?
It seems I won't have any hair left on my head when I master C_A + Singularity...
regards,
Krzysztof
#13 2023-11-21 13:03:02
k_zurawski
in my case this is the result:
user@MALUCH:/opt/sm$ ls
README  bin  resources  salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif
user@MALUCH:/opt/sm$ salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif shell
salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif: command not found
I have no idea why it runs on your machine and on my not.
regards,
Krzysztof
#14 2023-11-21 13:58:26
no !
but salome_meca-lgpl-2021.1.0-1-20220405-scibian-9.sif  is at the root of my home directory
i think  i has to be there
that does not seems to be the case with you
#15 2023-11-21 14:18:00
I just briefly describe what I do, my container is in my home directory (  ~/ or   $HOME or   ${HOME} ), I think every other location is very impractical. Current working directory is also ~/, you can check the working dir with the 'pwd' command.
With
singularity run --app install salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif
the container is installed. Because I do not use code_aster at the command line, I would normally run SM now. But in your case I would type:
./salome_meca-lgpl-2022.1.0-1-20221225-scibian-9 shell
The ./ is CRUCIAL (it even says so in the text after container installation!), it executes the file (this is a common command in Linux). In Msr. Aubry's case it is missing maybe because he made it executable beforehand, but I do not know. Now you are in the container shell where you can type
or the other command above with xterm. As you can tell by the attached screenshots, this works.
#16 2023-11-21 14:23:27
humm my mistake i typed it too fast previously
to run the singularity shell i do as follow
singularity run -B /dedalus /home/dedalus/salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif shell
with the following explanation
singularity run :
to run the following command
-B /dedalus :
to bind (give access) to the dir named dedalus at the root of my system
all my code_aster problems are located in sub dirs of that dir
this may be omitted if you run files within $HOME
/home/dedalus :
is my $HOME dir
/salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif :
is the salome_meca container
shell :
to launch the shell
#17 2023-11-21 22:49:06
k_zurawski
Thank you mf and Jean Pierre.
A word of explanation is needed. I don't have access to Linux machine now and I don't know if or when will it change. I have to use WSL to run Salome_Meca. Thanks to Hassan Berro's effort the VM works. I had problems with paravis on that VM and other problems with Windows port of Salome_Meca 2021. So I decided to use the newest Salome and Paraview standalone prepared for Windows plus run simulation on the latest version of C_A in terminal/PowerShell.
Thanks to you Guys I was able to run simulation in PowerShell. Evidence (input files are in my Downloads Windows folder):
                                            cpu    système    cpu+sys     écoulé
   Préparation de l'environnement          0.00       0.00       0.00       0.00
   Copie des données                       0.06       0.03       0.09       0.10
   Exécution de Code_Aster                 7.94       3.32      11.26      13.83
   Copie des résultats                     0.04       0.04       0.08       0.13
   Total                                   8.45       3.51      11.96      14.74
as_run 2021.0
--- DIAGNOSTIC JOB : OK
EXIT_CODE=0
Singularity>
Now I have almost everything I need. I'd like to simplify the way to run the simulation. Maybe bind a Windows folder to /Home/User?
You may add an alias to .bashrc file to run container. So in my case if all the studies would be in Downloads subdirectories entry in bashrc would look like this:
alias sm22='/opt/sm$ singularity run -B /mnt/c/Users/KrzysztofZurawski/Downloads/ salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif shell'
Then you can simply write in terminal sm22 to run the container.
regards,
Krzysztof
#18 2023-11-21 22:56:28
k_zurawski
The alias doesn't work. I think I won't get rid of a sort of script, like the one I added at the beginning of this thread. I'll park this one for now.
regards,
Krzysztof
#19 2023-11-21 23:28:24
k_zurawski
On second thought...
...for someone who would like to run simple command from terminal and your user folder in Linux is just named user:
If you place salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif anywhere else in the system (in this case /opt/sm) create empty file in your /home/user and name it .sm22 (dot before the file makes it hidden)
add these lines to the file:
#! /bin/sh
singularity run /opt/sm/salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif shell
save and close
add a line anywhere where aliases are in your hidden .bashrc file (the .bashrc file is in your home directory):
alias sm22='/home/user/.sm22'
save and close
Make .sm22 executable and reload .bashrc by writing in terminal:
chmod +x ~/.sm22
source ~/.bashrc
If all went ok then you may simply run terminal and write sm22 and it will run.
If you have an export file, cd to the location and run it by writing:
as_run example.export
voila!
regards,
Krzysztof
#20 2023-11-21 23:31:00
k_zurawski
What was left is mounting/linking
to my /home/user directory.
regards,
Krzysztof
#21 2023-11-27 21:03:09
k_zurawski
well... for part of this conversation I tried to solve already solved problem. By mistake I discovered that I don't have to run singularity inside wsl "VM". Well, this has already been prepared and if you are using what Hassan Berro prepared, after running
wsl -d smeca
you simply run
as_run exampleexportfile.export
and that's it. It works flawlessly...
So to sum up -
all I have written before applies to singularity installed directly on Linux machine. There's no need to change anything in shared "VM".
regards,
Krzysztof
