#1 2022-01-16 16:56:50
smr02
Salome-Meca on arm64 based system
Hello!
I'm trying to install Salome-Meca on a virtual machine on a M1 MacBook.
Is it possible to download or create a arm46 based singularity container?
singularity run salome_meca-lgpl-2021.0.0-0-20210601-scibian-9.sif shell
FATAL:   could not open image /home/ubuntu/salome_meca-lgpl-2021.0.0-0-20210601-scibian-9.sif: the image's architecture (amd64) could not run on the host's (arm64)
#2 2023-05-11 13:43:53
Solenne
Re: Salome-Meca on arm64 based system
We are having the same issue with one of our marchines. Any update on this ?
#3 2023-05-12 09:50:50
nicolas_p
This is not planned for the moment.
Building code_aster on arm64 is not possible for the moment
#4 2023-05-23 22:14:25
smr02
the only way i have found to run code_aster (not salome) on a modern macbook is within docker.
Check out this great docker container on Github:
github.com/aethereng/docker-codeaster
