#1 2023-04-19 01:56:07
Penta
Case of a belt under its own weight: computed dispacement is too large
Im currently working on the simulation of a belt (20 m long, 1.6m large, 1.5 mm thick) which is suspended between two edges. I used DKT element, and im using N/mm/s/ton unit system. The DZ displacement computed is way too large (around 8e5 mm, so about 800m which is 40 the total length). Im not sure what I've done wrong, but I tried unit test:
- Estimate the mass of the part, seems ok
- test pesanteur on one single element, seems ok
- Test a cantilever configuration with low linear effort, seems ok
However, when running mumps solver, I need to increase a little the tolerated error to make it run (3e-6 instead of 1e-6). I also tried non-linear solving, I have the same Issue. I tried to use membrane, but never succeed to make it run because the matrix is singular.
I enclosed the .comm file and the HDF too. I'd be happy if someone could provide some insight, comment or advice for my case.
Thank in advance,
Penta
#2 2023-04-19 10:46:34
jonas loenartz
Re: Case of a belt under its own weight: computed dispacement is too large
Can you post the .comm-file and the mesh?
Jonas
#3 2023-04-19 10:53:15
Penta
Sorry about that, here they are. Also Im quite a new Code_Aster user, there might be some reflexes I wont have. Im using Salome-Meca interface to run thing too.
#4 2023-04-19 12:08:18
jonas loenartz
I couldn't find any abvious mistakes on a first glance. I will further look into this, when I'm home.
#5 2023-04-19 15:50:37
Penta
Thank you for your time!
I ran some other tests like increasing the thickness, and it gace a plausible result. I might have an idea of whats going on but I'm not sure at all. My guess relies on those assumption:
     - Gravity is computed using volume (surface x thickness) multiplied by density
     - Gravity is estimated at each step
     - The element deforms and the thickness doesn't change
So basically the gravity force on each element can increase as the overall volume, and so the mass of the element increases too (bad Poisson coeff estimation on the shell element). If the stiffness cannot maintain balance it just deforms to very large values. Do you think this could happen?
Thanks again for your help and your time,
#6 2023-04-19 18:38:15
miib
please give me back this values :
young_mod = 205e3
grav = 9810
density = 7.9e-9
# Thickness of the belt in mm
thick = 1.5
in I.S. (International Standard) and write the units near to them right.
smile
Mechanical Engineer.
CAD 3D designer with 15 years of experience. I use Code_Aster since 2019, initially for curiosity, sequentially with enthusiasm ( during COVID-19 period permitted to me a re-study of my university notions). Also Nastran user (leaved), Inventor Simulation user (leaved). smile
#7 2023-04-19 20:24:10
Penta
Hi Miib, here are the values in IS:
young_mod = 205e9 #Pa
grav = 9.810 #m/s²
density = 7900 # kg/m³
thick = 1.5e-3 #m
#8 2023-04-19 21:03:03
miib
grav = 9.810 #m/s²
thick = 1.5e-3 #m
Thank you
it is steel
in the next days (i haven't wife/girlfriend ) i will study (gratis) your case.
Stay tuned .
smile
#9 2023-04-19 21:57:24
k_zurawski
JDC.py : ERREUR A L'EXECUTION - INTERRUPTION
>> JDC.py : DEBUT RAPPORT
CR d'execution de JDC en MIXTE
   ! <S> Exception utilisateur levee mais pas interceptee.       !
   ! Les bases sont fermees.                                     !
   ! Type de l'exception : error                                 !
   ! Solveur MUMPS :                                             !
   !   La solution du système linéaire est trop imprécise :      !
   !   Erreur calculée   : 2.63157e-06                           !
   !   Erreur acceptable : 1e-06   (RESI_RELA)                   !
   ! Conseils :                                                  !
   !   On peut augmenter la valeur du mot clé SOLVEUR/RESI_RELA. !
fin CR d'execution de JDC en MIXTE
well, it's quite deformed for linear elastic
regards,
Krzysztof
#10 2023-04-20 10:59:16
Penta
Hi everyone,
Thanks again for your help and your time. I've done few more test, especially mass estimation at initila state (that i've done before) but also after deformation: The mass actually increases during computation from 3.79200E-01 ton (379.2 kg) to 3.13166E+01 ton (31 316 kg)!
The more I look at it, the more I think there is a loop between element deformation that increases the volume and the element mass, and weight estimation that increases element length. What do you think, is this something that have been seen somewhere?
Thank you all
#11 2023-04-20 11:07:45
jonas loenartz
Hello, I have run your case, and I got the same strange results. I checked your mesh and your input-data and there is nothing wrong with it. I built the exact same model with Altair Hypermesh and ran the analysis using the mechanical solver "optistruct". The results are practically identical. Max DZ is around 8e5mm.
So this is not a problem of code_aster specifically, but rather lies in the nature of the mathematics behind FEM in general. I have to admit that my knowledge of the theory of the finite element method does not go beyond the basics.
I think this could be a case fo a nonlinear-analysis with large displacement. I think the initially calculated matrix of rigidity for the flat belt is just wrong and does not represent the state of the belt hanging through at all (maybe someone with more knowledge about the theory of FEM can explain this a little better).
Jonas
#12 2023-04-20 11:41:12
jonas loenartz
Penta wrote:
Hi everyone,
Thank you all
That is 100% not the case. You are doing a linear static analysis. You have a matrix of rigidity and vector of external forces. The basic equation of linear elasticity is rigidity * displacement = external forces. The solver solves this equation for the displacements. The matrix of rigidity is calculted for the initial geometry as is the gravity load (based on volume * density, spread on the nodes of the mesh). In non-linear analysis, the matrix of rigidity is recalculated for the deformed geometry after a given number of iterations.
Edit: Think about the belt like a tightrope. In its initial state, a tiny force in the middle between its two ends is enough to make it sag, because the rope has no angle to counter the force in the center. The more the rope sags and the greater the angle gets, the greater the force has to be, to push the center further down. In your analysis the calculation is done with the rigidity of this initial state, where a tiny force is enough to bend your belt to infinity.
Try the following: Make the belt slightly v-shaped, just to test for plausibility. I bet you won't see these large DZ-values anymore
#13 2023-04-20 12:27:39
jonas loenartz
Ok, I tested the v-shaped geometry and this gets even weirder. I attached screenshots of the displacement-field. In the wedge of the v-shape the displacement is small, but in the two straight parts left and right of it, we have the same problem as before. This is getting interesting big_smile
But I stand with my explanation until someone corrects me. I think theres something wrong with the rigidity.
Jonas
#14 2023-04-20 13:31:20
Penta
Wow, ok right, thats weird haha. Thanks for the explanation, Im trying to redo simulation of the gravity using nodal reaction. This would confirm your idea I guess as nodal forces should be independent from any geometry variable.
#15 2023-04-20 14:55:56
hello all
i wonder what you guys find strange in here
a MECA_STATIQUE analysis  gives exactly the same results as a quick analytic with beam theory
the contrary would be strange
#16 2023-04-20 15:20:08
jonas loenartz
jeanpierreaubry wrote:
hello all
You are right of course. I rarely have to use the analytical approach, so when it is a good idea to use it, I don't think about it at all ... So Beam-theory and MECA_STATIQUE give results, that don't match reality... STAT_NON_LINE is the way to go then, or do you have another, easier idea, M. Aubry?
#17 2023-04-20 16:01:30
oh yes i have an idea!
as an engineer i would never build something with these figures after a quick analytical approach
that is all
the result is so far out that a  STAT_NON_LINE will not proove the structure to be feasible
#18 2023-04-20 16:18:39
Penta
Im not trying to build anything, just understanding a case of a belt under its own weight. I'll take a look at the elastic catenary equation to see if it match the order of magnitude.
Edit: The nodal force give the same result, so I think you were right Jonas.
#19 2023-04-20 18:46:44
miib
Penta wrote:
pity you could build a plate on the rolls of a rolling mill before it is cut and coiled big_smile
(in the pic the scale factor is multiplied "x 50")
#20 2023-04-21 11:26:17
Penta
Yep this is the kind of stuff, but a lot more thinner haha.
#21 2023-04-21 17:18:36
miib
big_smile
nyprohutni.cz/deleni-ocelovych-svitku
#22 2023-05-25 10:20:44
jonas loenartz
Have you found a solution for your problem. For I am currently facing a rather similar challenge and I am interested in calculating the bending line of an elastic rope or band. The catenary curve doesn't apply here, because it is for untightened and unelastic ropes only.
