#1 2022-11-15 20:14:18
traemand
Show applied forces in pre/post
Hello there,
I've been wondering about this for a while, and it's starting to get on my nerves. I would like a visual representation of the forces and BC's applied to the model, to quickly check for proper directions, areas etc. I havent been able to make salome_meca show me this in AsterStudy (i'd prefer that) before running the study, and neither in Post-proces/ParaVIS.
Can anyone tell me how this is possible to do?
#2 2022-11-21 19:44:19
traemand
Re: Show applied forces in pre/post
Anyone?
#3 Yesterday 09:40:33
jonas loenartz
I believe this is not possible, for the following reasons. When you set up a stage in AsterStudy, by adding keywords you merely code the instructions the solver is goint to interpret during the run. Salome-Meca would need vectors to represent the loads as arrows for example. The corresponding vectorfield to the load is created during the run.
Jonas
#4 Yesterday 14:04:04
jacob
You can still display "selected surfaces" where the bcs are applied. If you want vectors, you can always display REAC or FORC in paraview.
#5 Yesterday 21:32:47
Irvise
Just to add to what Jacob said.
You can use CALC_CHAMP to calculate the Force or Reaction that is applied in a BC. See document u4.81.04. You can run a single timestep to achieve a initial stable solution and then see how the values of those fields compare to what you want.
Fernando
