#51 2022-03-29 18:49:44
VonPire
Re: Questions about singularity version of salome_meca 2021
Okay, I understand that.
The newest stable version seems to be 15.5.0 ? (htt ps://sourceforge.net/p/codeaster/src/ci/stable/tree/) If that doesn't work with the newest salome_meca 2021.0.0-2-20211014 container then try it with older salome_meca 2021.0.0-0-20210601 container. Hope it works ! smile
VonPire
#52 2022-03-30 16:41:27
well, I was quite positive when everything compiled and built correctly (I had to --disable-petsc also). But in the end, there was no MUMPS compiled, which I overlooked. So, that doesn't work (15.5 and the newest container),
#53 2022-04-17 03:15:34
linctus
According to https: //gitlab.com/codeaster-opensource-documentation/opensource-installation-development/-/blob/main/devel/changelog.md there is comparability of aster and singularity container images.
starting from 16.0.12:
salome_meca-lgpl-2021.0.0-2-20211014-scibian-9
starting from 16.0.6:
salome_meca-lgpl-2021.0.0-1-20210811-scibian-9
starting from 16.0.0:
salome_meca-lgpl-2021.0.0-0-20210601-scibian-9
starting from 15.3.17:
#54 2022-04-28 11:41:37
drPcb
Hallo!
I also tried the MPI compilation described in:
https: //github.com/emefff/Code-Aster-MPI-in-Singularity-of-SM2021
and by disabling MFRONT it worked (without disabling MFRONT I got an error message regarding META_LEMA_ANI.cxx).
However, after runnning:
singularity run --app install salome_meca-lgpl-2021.0.0-0-20210601-scibian-9.sif
./salome_meca-lgpl-2021.0.0-0-20210601-scibian-9
stops with:
OSError: [Errno 30] Read-only file system
singularity exit code: 1
Any suggestions what the problem is?
Many thanks in advance!
#55 2022-08-04 16:55:18
jacob
Hello, I tried to download the container from
https:// cloud.sylabs.io/library/emefff/collection/code-aster-mpi-in-singularity-of-sm2021
,but the download does not start. Is something wrong with it?
#56 2022-08-05 16:58:49
jacob
Ok I was able to download it and install it, but the MPI version is quite slower if I choose more CPU.
I have a small problem with linear mesh, but nonlinear study. Normally it takes about 10 min. So, I wont be able to reduce solution time since the problem is small? I would have to have many DOFs to notice performance increase?
