Hello everibody.
Recently I istalled Salome_Meca for windows on a windows 10 PC. This is the first time I try to use Code_Aster on windows, after several years of Linux version, because in this period I am using a windows PC and I don't have availability of a linux one (temporarly, I hope).
I downloaded the compressed 2021 version Salome Meca for windows, I extracted the package in a dedicated directory and I run the batch file.
All works well, I loaded my still existing models, BUT at the moment to launch the analysis an error window opens:
AsterStudy
Unespected Error
Type: ModuleNotFoundError
Value: ("No module named asrun",)
It looks not a problem of the model, but something about the launch of Code_Aster...
An update:
In the lauch shell there is this message:
ERROR : Code_Aster installation not found on this machine. ASTERSTUDY module will not found any Code_Aster version
You may download and install 'code_aster 2021 msi' package available at code-aster-windows.com/download
It looks that Code_Aster is not ptresent, and it looks a bit strange to me that I installed the full package following the simple instructions...
PROBLEM SOLVED:
Following the suggestion in the shell window, I installed the 2021 Code_Aster for windows (it is a full installation, not a simple extraction of files). Now all the package works well.
