Hi everyone ,
I import STEP. file of complex geometry , but i need to detect short edges and small areas during in the geometry module which will cause meshing problems.
In ANSYS there is selection command to select edges by length for this.
How can i ensure that in geometry module ?
Naval Architect and Marine Engineer
I found a solution with creating groups.
I explode model into the edges and creating groups with ''less than''.
