#1 2022-06-08 10:32:40
code_asterneedhelp
use of happen
hello i ve been strugling with the function happen to automatise
and here is the error message
File "fort.1", line 473, in <module>                                         !
   !     c.append(_F(NOEUD=na), NOM_CMP = TEM, VALE = 3)                             !
   !  TypeError: append() takes no keyword arguments                                 !
can anyone explain to me  what is the problem?
#2 2022-06-13 18:46:04
Yves POUSSET
Re: use of happen
In python "append" takes only one argument (any object to be added into a list) - without "=".
#3 2022-06-17 08:44:00
code_asterneedhelp
Re: use of happen
thank you very much
