#1 2022-05-18 09:28:58
ruggekutta76
install problem
Hi everyone,
during installation on ubuntu 20.04 i've problem with "LIBPATH_HDF, LIBPATH_MED, LIBPATH_METIS, LIBPATH_MFRONT, LIBPATH_MUMPS, LIBPATH_SCOTCH" (row 918).
Someone can help me please?
kind regards
#2 2022-05-22 03:27:46
linctus
Re: install problem
Hi there,
It looks like you put ASTER_ROOT='/home/andrea2/Scrivania/code aster' in setup.cfg file and that's the cause of problem.
In configure stage '--prefix=/home/andrea2/Scrivania/code aster/public/***' are treated as two parameters (options):
'--prefix=/home/andrea2/Scrivania/code' and 'aster/public/***' but the later one is not recognized so it raised the error.
You can try
ASTER_ROOT='/home/andrea2/Scrivania/code_aster' or ASTER_ROOT='/home/andrea2/Scrivania/code-aster' or something like that, point is don't put any space in a file name or directory name.
#3 2022-05-28 14:50:46
ruggekutta76
Re: install problem
ok thank you now it is correctly installed!!
kind regards
