I'd like to find code_aster version 14.02.00, because the modal base was computed on a server that use this version, and the code_aster version difference seem to be an issue as suggested in the mess file:
! <A> <JEVEUX_08> !
! La base GLOBALE a été constituée avec la version 14.02.00 !
! et vous utilisez la version 14.08.00 !
! Conseil : !
! En général, la base ne peut-être utilisée qu'avec la version du code l'ayant construite, !
! les catalogues d'éléments sont stockés dans la base lors de sa création, or certaines structures de !
! données s'appuient sur leur description qui peut varier d'une version à l'autre. !
I can't find this version on the website, so where can find previous version of code_aster (version 14.02.00) or Salome-meca ?
If I need to rebuild code_aster, I am not sure if I should access bitbucket or Mercurial, I found different indication of code_aster website.
When I try to access the bitbucket repo, I get the following error message: "Repository not found".
And when I try to access Mercurial with "hg clone http:// aster-repo.der.edf.fr/scm/hg/codeaster/devtools", I get the error 'abort: error: No address associated with hostname'.
If I need to rebuild code_aster, where can I access code_aster repository so that I build code_aster version 14.02.00.
You have to rebuild your own version (with appropriate prequisities)
Use git instead: https: //gitlab.com/codeaster/src
Thanks for you help.
