#1 2019-10-24 13:41:23
GPSalachs
[SOLVED]How can i export nodes or node coordinates?
Hello all,
i would like to ask if it is possible to export in a python script inside the .comm file the nodes or nodes coordinates.
Where should i search for this particular operation?Through the documentation i might have missed something, are there
any suggestions?
Thank you.
#2 2019-10-28 08:06:45
Re: [SOLVED]How can i export nodes or node coordinates?
you can access the nodes coordinates with the following commands:
DEBUT(PAR_LOT='NON')
from Utilitai import partition
mesh0 = LIRE_MAILLAGE(FORMAT='MED',
                      UNITE=2)
mesh0=DEFI_GROUP(reuse=mesh0,
                 MAILLAGE=mesh0,
                 CREA_GROUP_MA=_F(NOM='tout', TOUT='OUI',),);
mesh1 = partition.MAIL_PY()
mesh1.FromAster('mesh0')
el_no = mesh1.gma.get('tout')
for el in el_no:
    for node in mesh1.co[el]:
        print('Node number: {!s}, coordinates: {!s}'.format(node, mesh1.cn[node]))
Related topics:
- https://code-aster.org/forum2/viewtopic.php?id=23914
- Jean-Pierre's book: §18.4
#3 2019-11-05 12:20:21
GPSalachs
Thank you very much for the code and the reference provided.
I have read and still reading  Jean Pierre's book but in a bible like that things are missed.
A question if i may. Since it is possible to extract node coordinates, is it also possible to extract the connecting lines coordinates too?
Thank you in advance!
#4 2019-12-14 05:50:15
I don't think there are some direct information about the connecting lines. I printed print(dir(mesh1)) but found nothing relevant.
#5 2022-04-15 13:09:20
hello konyaro and GPSalachs
unfortunately this throws the following message
from version 15 on
ModuleNotFoundError: No module named 'Utilitai'
i am still struggling to find out what could be the right alternative with today's version
in my opinion this is a major regression as i used that feature quite a lot do define loads and many other things
#6 2022-05-04 17:23:46
Matt141
MAIL=LIRE_MAILLAGE(FORMAT='MED',);
xyz = np.asarray(MAIL.sdj.COORDO.VALE.get())
Nc = int(len(xyz)/3)
xyz = xyz.reshape((Nc, 3))
