#1 2022-04-04 14:26:41
jacob
rbe2 and rbe3 / MPC / joints
what is the correct way to create hinge (or any other constraint) using rbe2 or rbe3 in salome meca?
I tried LIAISON_DDL and LIAISON_RBE3 but I haven't found a way how to use it on simple solid.
I also read there is a way how to do it using springs where one could define local coordinate system, but I guess I would spent hours trying.
#2 2022-04-04 14:53:14
Re: rbe2 and rbe3 / MPC / joints
can you share the command file i am unable to extract them from the hdf file
also Mesh_2 seems strictly identical to Mesh_1
review your files before sharing
creating hinges on a line deined at mesh time is one of the easiest thing to do in code_aster
there are examples in my book
#3 2022-04-04 17:23:03
jacob
Sorry I forgot to mention the file is hdf with AS, now hinge_beam_AS.hdf. The other hdf is for the mesh. I am using latest salome for the mesh but salomemeca2018 for solving.
#4 2022-04-05 08:13:05
i do not understand what you are trying to do
1- a quadratic is unnecessary here, maybe harmful?, please revert to a linear mesh
2- i do not understand what the  RBE3 is supposed to do
anyhow DRX, DRY and DRZ DOF are not allowed in 3D modeling
3- node 3424 belongs at Group_1 and Group_2 and Face_1? this is strange try to put it at Z= slightly below Face_1
#5 2022-04-05 08:40:46
my way to create an hinge (used many times)
create one node at x=0, y=0, z=-0.1 (slightly below Face_1)
make a LIAISON_SOLIDE between that node and Face_1
create a another node at x=0, y=0, z=-a (value of a at your choice)
fix its  6 DOF
make a SEG2, line element, between these two nodes
model it as a K_TR_D_L and give it the required properties
there are some examples in my book
#6 2022-04-05 10:05:50
jacob
What I am trying to do is this.
So it has to be modelled as you are saying, I have to use spring? I cannot just constraint DX DY DZ (leave rotations free) at master node and couple it with nodes on left face using LIAISON_RBE3 or SOLID?
#7 2022-04-05 10:21:03
maybe
i have always done the way i describe
your problem as far as i understand is that the node supposed to be the hinge does not seem to be seen
maybe because it is lying at the same z as Face_1
i never use  Salome to build my mesh so i have no idea about that
#8 2022-04-05 12:44:02
jacob
Alright I managed to do that as you said and it works.
Thank you.
I also tried using K_TR_D_N (it seams more appropriate, so I don't have to use line element) and I guess it works.
#9 2022-04-05 12:58:31
Thank you.
NO !
it does not work the same way
have a  look at page 313 of my book
#10 2022-04-05 13:27:06
jacob
So if I managed to do RBE3 like that I should rather use K_TR_D_L?
If I understood it correctly I guess it is wrong when used for joint but since it is just connection to the ground it is ok. In my case it should be ok.
Am I wrong?
#11 2022-04-05 16:07:24
t would nice if you gave some explanation about the various files
i can see 5 diffrents command files
what does each of them
#12 2022-04-05 19:22:05
jacob
Well if you look just on comm, the last one is important.
__________________________________________________
##LIAISON_SOLIDE
mesh = LIRE_MAILLAGE(UNITE=2)
model = AFFE_MODELE(AFFE=(_F(MODELISATION=('3D', ),
                             TOUT='OUI'),
                          _F(GROUP_MA=('0d', ),
                             MODELISATION=('DIS_TR', ),
                             PHENOMENE='MECANIQUE')),
                    MAILLAGE=mesh)
elempro0 = AFFE_CARA_ELEM(DISCRET=_F(CARA='K_TR_D_N',
                                     GROUP_MA=('0d', ),
                                     VALE=(1.0, 1.0, 1.0, 1.0, 1.0, 1.0)),
mater = DEFI_MATERIAU(ELAS=_F(E=200000.0,
                              NU=0.3))
fieldmat = AFFE_MATERIAU(AFFE=_F(MATER=(mater, ),
                                 TOUT='OUI'),
load = AFFE_CHAR_MECA(DDL_IMPO=(_F(GROUP_MA=('fix', ),
                                   LIAISON='ENCASTRE'),
                                _F(DX=0.0,
                                   DY=0.0,
                                   DZ=0.0,
                                   GROUP_NO=('node', ))),
                      LIAISON_SOLIDE=_F(GROUP_NO=('hinge', 'node')),
                      PRES_REP=_F(GROUP_MA=('press', ),
                                  PRES=10.0))
reslin = MECA_STATIQUE(CARA_ELEM=elempro0,
                       CHAM_MATER=fieldmat,
                       EXCIT=_F(CHARGE=load),
reslin = CALC_CHAMP(reuse=reslin,
                    CRITERES=('SIEQ_ELGA', 'SIEQ_ELNO', 'SIEQ_NOEU'),
                    RESULTAT=reslin)
IMPR_RESU(RESU=_F(RESULTAT=reslin),
          UNITE=3)
____________________________________________________
##LIAISON_RBE3
                             TOUT='OUI'),
                    MAILLAGE=mesh)
                                     GROUP_MA=('0d', ),
                              NU=0.3))
                                 TOUT='OUI'),
                                _F(DX=0.0,
                                   DY=0.0,
                                   DZ=0.0,
                      LIAISON_RBE3=_F(COEF_ESCL=(1.0, ),
                                      DDL_ESCL=('DX-DY-DZ', ),
                                      DDL_MAIT=('DX', 'DY', 'DZ'),
                                      GROUP_NO_ESCL=('hinge', ),
                                      GROUP_NO_MAIT=('node', )),
                                  PRES=10.0))
                    RESULTAT=reslin)
          UNITE=3)
