#1 2022-03-29 21:10:59
jacob
select body/surface in paravis
lets say I have done static study on an assembly. How do I show results only on some parts or surfaces?
(I mean automatically, not manually selecting cells and then extract selection. It is not possible on something complex)
#2 2022-03-29 21:35:18
Irvise
Re: select body/surface in paravis
Hi Jacob,
Code_Aster allows you to do post processing of the generated results on specific areas. Most (if not all) post-processing commands have a GROUP_MA or GROUP_NO to restrict the post processing of whatever you want to that group.
If you are talking about ParaVis/Paraview, you can use the threshold filter. It allows you to get rid of parts of the results depending on your criteria. If you have groups in your mesh, those will be present in the results. In the threshold filter select the filter to be based on FamilyCell or FamilyNode and tweak it to leave only the part that you actually want.
Fer
#3 2022-03-30 07:35:58
jonas loenartz
Hello Jacob,
if you use Paravis for your post-processing you can also use the filter "extract groups", to isolate the values by mesh groups (GROUP_MA and GROUP_NO) you defined during the pre-processing. No need to choose cells in advance.
Jonas
#4 2022-03-30 08:34:05
jacob
Yes I tried that before I posted, but it does not show anything. I tried many models.
#5 2022-03-30 13:39:35
jonas loenartz
The filter has so far not failed me. But your property-browser looks kind of strange to me, as if you are not using the filter on the right object. It looks like your result file is "leaf_spring_contact_AS.rmed" but you use it on some other object in the pipeline browser. You have to select the object you want to apply the filter to in your pipeline browser, so that it has a blue background.
it would help, if you could share the .rmed file
Jonas
#6 2022-03-30 19:45:13
jacob
hmm on volme it works, but not on the surfaces.
However I have to prepare everything before solving I guess?
#7 2022-03-30 20:35:19
you can use the filter "Resample with dataset", refer to :
old.salome-platform.org/forum/forum_10/298627693#336367220
#8 2022-03-31 08:50:29
jonas loenartz
Ok, I was not able to to extract a group of surface-elements in your result file. General it shoud be possible (as you can see in the attached screenshot, where I did it with one of my models.)
I'll have a look into your model later when I have time, in order to check if everything defined correctly in there
Jonas
#9 2022-04-02 13:09:22
jacob
I tried it on Salome Meca 2021 on Xubuntu but it behaves the same. Only volume works.
#10 2022-04-03 20:50:21
This is explained in the Salome post I gave you above. Again, a workaround is to use the "Resample with dataset" filter.
#11 2022-04-03 22:19:12
jacob
I tried that but it also does not work.
#12 2022-04-04 06:53:50
You must apply the "Extract Group" on the mesh (MED), not on the rmed result, and then link the extracted group to your result with the "Resample with dataset".
#13 2022-04-04 07:03:57
jacob
Yeah I realized later. But thanks anyway.
