#1 2022-01-22 20:08:28
lskrinjar
[Solved] DOF error node N1 at cmp. DY - geometry crated with Partition
Dear all,
I am trying to model a beam structure with two overhangs and 4 supports. The procedure to model the geometry and mesh I have taken from my other models (that work OK) and I join specific lines with Partition in Geometry workbench in SalomeMeca (as usual). But here I am having problem with the CodeAster calculation as I receive that the first node (N1) of the mesh (tip of the overhang) has free movement in direction DY. Attached are the files.
Do you have any ideas what is wrong here?
Thank you for your answers!
lskrinajr
#2 2022-01-23 11:17:13
lskrinjar
Re: [Solved] DOF error node N1 at cmp. DY - geometry crated with Partition
I have solved the problem. I had to remove the user settings for the solver. With default settings it completes the calculation.
Best,
