Hi to everyones,
i am performing a modal analysis that on 07/01/2022 going succefully to solution (and the results was the same obtained with Ansys).
Today, on 11/01/2022, after Windows update, i am obtaining this error:
! <S> Exception user raised but not interceptee. !
! The bases are fermees. !
! Type of the exception: error !
! error LAPACK (or BLAS) on the level of the routine DLASCL !
! the parameter number 4 !
! does not have a coherent value 4 !
I don't know what it is. I am using codeaster for windows.
The strange thing is that if i impose Rigi_Meca both for M and K Matrix in calc_modes analysis the results go to solution.
Instead if i set Rigi_Meca as K Matrix and MAss_Meca as M Matrix, the solution give me this error.
I have also try to restore the pre-update version of windows but nothing changed.
I have perfomed a buckling analysis obtaining the right solution. So i think that the problem is regarding only the Dynamique algorithm used in Calc_Modes.
I attach the .comm file.
Thanks to all for the reply.
mahhhh!!!!
sometime i do this:
go to AppData\Local\Temp , folder -> delete all.
after
reinstall the package.
SE,Dio è il creatore di tutto, e tu credi in Dio, crederai anche che le formule della matematica e della fisica sono "linguaggi" che consentono di spiegare ciò che è stato creato da Dio (la natura) e che tali "linguaggi" sono essi stessi creazioni di Dio. Sarei stupito del contrario.
thanks for the reply.
I can't reinstall the package beacuse i am using codeaster_for_windows. So i don't know how it is possible install that package in a builted version of codeaster.
I have set in "CALC_MODES > SOLVEUR_MODAL>METHODE>SORENSES" and the analysis go to results.
I don't understand how it is possibile.
now explain
clear this
re extract
happy 4u
