#1 2022-01-11 17:14:45
Romans1988
[SOLVED] error LAPACK (or BLAS) on the level of the routine DLASC
Hi to everyones,
i am performing a modal analysis that on 07/01/2022 going succefully to solution (and the results was the same obtained with Ansys).
Today, on 11/01/2022, after Windows update, i am obtaining this error:
   ! <S> Exception user raised but not interceptee.             !
   ! The bases are fermees.                                     !
   ! Type of the exception: error                               !
   !  error LAPACK (or BLAS) on the level of the routine DLASCL !
   !  the parameter number 4                                    !
   !  does not have a coherent value  4                         !
I don't know what it is. I am using codeaster for windows.
The strange thing is that if i impose Rigi_Meca both for M and K Matrix in calc_modes analysis the results go to solution.
Instead if i set Rigi_Meca as K Matrix and MAss_Meca as M Matrix, the solution give me this error.
I have also try to restore the pre-update version of windows but nothing changed.
I have perfomed a buckling analysis  obtaining the right solution. So i think that the problem is regarding only the Dynamique algorithm used in Calc_Modes.
I attach the .comm file.
Thanks to all for the reply.
#2 2022-01-11 20:16:57
miib
Re: [SOLVED] error LAPACK (or BLAS) on the level of the routine DLASC
mahhhh!!!!
sometime i do this:
go to AppData\Local\Temp , folder -> delete all.
after
reinstall the package.
Mechanical Engineer.
Salome_Meca User.
C u m  grano salis.
Si lavora e si fatica per il pane e la φca.
#3 2022-01-12 09:36:34
Romans1988
thanks for the reply.
I can't reinstall the package beacuse i am using codeaster_for_windows. So i don't know how it is possible install that package in a builted version of codeaster.
#4 2022-01-12 10:00:04
Romans1988
I have set in "CALC_MODES > SOLVEUR_MODAL>METHODE>SORENSES" and the analysis go to results.
I don't understand how it is possibile.
#5 2022-01-12 19:26:25
miib
now explain
Salome_Meca User.
C u m  grano salis.
#6 2022-01-12 19:28:30
miib
clear this
Salome_Meca User.
C u m  grano salis.
#7 2022-01-12 19:30:18
miib
re extract
Salome_Meca User.
C u m  grano salis.
#8 2022-01-12 19:31:26
miib
happy 4u
Salome_Meca User.
C u m  grano salis.
