Hi
I meet an error .
First it comes when :dev/codeaster/src/build/std/release/catalo/fort.1 --memory=4096
It tells me I need more memory than 4096.I didn't build a /.hgrc .
To run manually, use:
export LD_LIBRARY_PATH="/home/whb/dev/codeaster/install/std/lib/aster:/home/whb/aster/public/hdf5-1.10.3/lib:/home/whb/aster/public/med-4.0.0/lib:/home/whb/aster/public/metis-5.1.0/lib:/home/whb/aster/public/scotch-6.0.4/lib:/home/whb/aster/public/mumps-5.2.1/lib:/home/whb/aster/public/tfel-3.2.1/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/python3.6/config-3.6m-x86_64-linux-gnu:/home/whb/aster/public/hdf5-1.10.3/lib:/home/whb/aster/public/med-4.0.0/lib:/home/whb/aster/public/metis-5.1.0/lib:/home/whb/aster/public/scotch-6.0.4/lib:/home/whb/aster/public/mumps-5.2.1/lib:/home/whb/aster/public/tfel-3.2.1/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/python3.6/config-3.6m-x86_64-linux-gnu:/home/whb/dev/codeaster/install/std/lib/aster:/home/whb/aster/public/hdf5-1.10.3/lib:/home/whb/aster/public/med-4.0.0/lib:/home/whb/aster/public/metis-5.1.0/lib:/home/whb/aster/public/scotch-6.0.4/lib:/home/whb/aster/public/mumps-5.2.1/lib:/home/whb/aster/public/tfel-3.2.1/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/python3.6/config-3.6m-x86_64-linux-gnu:/home/whb/aster/public/hdf5-1.10.3/lib:/home/whb/aster/public/med-4.0.0/lib:/home/whb/aster/public/metis-5.1.0/lib:/home/whb/aster/public/scotch-6.0.4/lib:/home/whb/aster/public/mumps-5.2.1/lib:/home/whb/aster/public/tfel-3.2.1/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/python3.6/config-3.6m-x86_64-linux-gnu:"
export PYTHONPATH="/home/whb/dev/codeaster/install/std/lib/aster:/home/whb/.local/lib/python3.6/site-packages:/home/whb/aster/lib/python3.6/site-packages:/home/whb/aster/public/tfel-3.2.1/lib/python3.6/site-packages:/home/whb/.local/lib/python3.6/site-packages:/home/whb/aster/lib/python3.6/site-packages:/home/whb/aster/public/tfel-3.2.1/lib/python3.6/site-packages:/home/whb/dev/codeaster/install/std/lib/aster:/home/whb/.local/lib/python3.6/site-packages:/home/whb/aster/lib/python3.6/site-packages:/home/whb/aster/public/tfel-3.2.1/lib/python3.6/site-packages:/home/whb/.local/lib/python3.6/site-packages:/home/whb/aster/lib/python3.6/site-packages:/home/whb/aster/public/tfel-3.2.1/lib/python3.6/site-packages:"
/usr/bin/python3 /home/whb/dev/codeaster/src/build/std/release/catalo/fort.1 --memory=4096
Command '/usr/bin/python3 /home/whb/dev/codeaster/src/build/std/release/catalo/fort.1 --memory=4096' returned 134
I followed its idea and another problem comes
<F> <JEVEUX_26> ║
║ Objet inexistant dans les bases ouvertes : &CATA.TE.NOMTE ║
║ l'objet n'a pas été créé ou il a été détruit ║
║ Ce message est un message d'erreur développeur. ║
║ Contactez le support technique. ║
║ Cette erreur est fatale. Le code s'arrête.
What should I do ?
