#1 2021-12-17 09:54:22
nirmaljoshi
Salome meca windows software throws error while running
I want to use windows version of code-aster. I downloaded it and after extracting the zip, I launched it.
It launches well. No problem.
Geometry and Mesh module works well. I created the geometry and mesh. No problem.
I launched Aster module and created command file. No problem.
But when I run the analysis, there is always some error such as
EXECUTION_CODE_ASTER_EXIT_XXXX=0
where XXXX changes every time I try to execute the analysis.
The .comm file is pretty simple and surely it has no error. What is going on? I need help.
Log file is copied below. MED and COMM file is attached, just in case.
I must mention that the windows pc I am trying to run is under LAN and controlled by IT guys of my office.
Active code page: 65001
Code_Aster execution
<INFO> prepare environment in C:\Users\JOSHI~1.NIR\AppData\Local\Temp\joshi_nirmalraj-PC0133-interactif_5552
Copying datas
copying ...\joshi.nirmalraj-PC0133-Fri-17-173448.778\RunCase_3_Stage_1.comm...
        copying ...\joshi.nirmalraj-PC0133-Fri-17-173448.778\mesh.med...        <INFO> Parameters : memory 2048 MB - time limit 900 s
Content of C:\Users\JOSHI~1.NIR\AppData\Local\Temp\joshi_nirmalraj-PC0133-interactif_5552 before execution
b''
Code_Aster run
<INFO> Command line 1 :
<INFO> C:\sm-2019-w64-1.2\PRODUCTS\code_aster\14.4\bin\aster C:\sm-2019-w64-1.2\PRODUCTS\code_aster\14.4\lib\aster\Execution\E_SUPERV.py -commandes fort.1 --num_job=5552 --mode=interactif --rep_outils=C:\sm-2019-w64-1.2\PRODUCTS\code_aster\outils --rep_mat=C:\sm-2019-w64-1.2\PRODUCTS\code_aster\14.4\share\aster\materiau --rep_dex=C:\sm-2019-w64-1.2\PRODUCTS\code_aster\14.4\share\aster\datg --numthreads=1 --suivi_batch --tpmax=900.0 --memjeveux=256.0
EXECUTION_CODE_ASTER_EXIT_5552=0
<INFO> Code_Aster run ended, diagnostic : <F>_ABNORMAL_ABORT
Content of C:\Users\JOSHI~1.NIR\AppData\Local\Temp\joshi_nirmalraj-PC0133-interactif_5552 after execution
b''
Size of bases
Copying results
<A>_COPYFILE       no such file or directory: fort.3
copying ...\fort.6...
<F>_ABNORMAL_ABORT Code_Aster run ended
                                            cpu     system    cpu+sys    elapsed
   Preparation of environment              0.00       0.00       0.00       0.00
   Copying datas                           0.00       0.00       0.00       0.06
   Code_Aster run                          0.00       0.00       0.00       0.75
   Copying results                         0.00       0.00       0.00       0.04
   Total                                   0.00       0.06       0.06       1.21
as_run 2018.1
--- DIAGNOSTIC JOB : <F>_ABNORMAL_ABORT
EXIT_CODE=4
#2 2022-01-11 17:52:05
Romans1988
Re: Salome meca windows software throws error while running
i have run your .comm file and there is no error.
How much memory you have given to the analysis?
Can you attach the .mess file?
