#1 2021-12-14 11:00:11
mu
[SOLVED] A big difference in simulation result between SW and Salome
We've conducted a transient thermal analysis using Salome and repeated the same with Solidworks for comparison. As you can see from the outcome below, both achieve thermal equilibrium of 29.xxx, however Salome took about 227s, while Solidworks took alot longer at 668s.
Question:
• What might have caused the two to take such a big difference in time?
• Is there a good way to determine which is "more accurate"?
model:
results:
#2 2021-12-14 11:10:17
mu
Re: [SOLVED] A big difference in simulation result between SW and Salome
Same geometry were used, checked that the units are the same too
• Same material, with heat flux density
• Mesh fineness at salome
• Mesh fineness at SolidWorks is default config
#3 2021-12-14 11:15:36
mu
model
#4 2021-12-14 11:28:30
mu
heat conduction between three solids and no external heat flux , no heat source
model conditions as below:
#5 2021-12-14 17:36:46
Volker
Is there an analytical way to obtain the function of thermal balancing?
Or other Question: which material property can you change to suppress geometrical nonlinearities as best as possible?
#6 2021-12-15 04:36:58
mu
Laplace's equation
Two materials:
AL7075 = DEFI_MATERIAU(
  THER=_F(LAMBDA=130.0, RHO_CP=2700000.0)
Sliver = DEFI_MATERIAU(
  THER=_F(LAMBDA=420.0, RHO_CP=2530000.0)
#7 2021-12-15 09:50:36
Volker
My question is: is there an analytical way to determine the function, see appendix. If we have this function then we can say clearly what is right and what is wrong.
#8 2021-12-15 10:08:51
RichardS
are you sure about your units?
In the mesh screenshot you say "mm", so I suppose thats the lenght unit you are using.
But in a later post where you have your material properties shown, it looks like SI units, with lenght unit "m".
Can you confirm which unit system are you using?
Best,
Richard
Richard Szoeke-Schuller
Product Management
www.simscale.com
#9 2021-12-15 10:20:37
mu
Hi, Volker
Our model do not have analytical solution.
#10 2021-12-15 10:36:45
mu
Hi, RichardS
I config the length units in study propertites
Which material property looks like SI units?  I don't understand the Material subject.
RichardS wrote:
Best,
Richard
#11 2021-12-15 10:39:06
Volker
Your sure there is not an exponential solution to base e?
#12 2021-12-15 12:17:24
Volker is probably right, your material parameters are most likely not correct. Your E is supposedly in N/m² RHO is in kg/m³, RHO_CP is also in SI units (the N-mm system value is much lower, see link to other post below), but your model is in mm. Only LAMBDA can be converted 1:1 (because W/mK is equal to mW/mmK)
Just like in https:__//www.code-aster.org/forum2/viewtopic.php?id=26082 you should correct your material parameters to the N-mm system, if you don't want to scale your model to meters.
EDIT: if you corrected the material parameters and you also choose the same timestep in both versions, then they should be comparable. The results will be very much alike.
#13 2021-12-15 12:21:25
This pdf helped me a lot, regarding consistent units,
#14 2021-12-15 17:28:34
Volker
Now I remembered the exact technical term: its a "solid" calorimeter.
Now its should be clear how to calculate by hand
#15 2021-12-17 04:01:28
mu
Thanks for all the help!
I solved this problem by importing the stp file which is exported from Salome into SolidWorks and change the units of SolidWorks from Custom(MM, G, S) to MKS(M, KG, S).
#16 2021-12-17 04:06:37
mu
Hi, Mario
Thanks for your help,  the results are very much alike just like you said.
#17 2021-12-17 04:09:46
mu
the .comm file
