Hello comunity,
I just did not finish a nonlinear contact simulation successfully and received the following error message:
! <EXCEPTION> <CALCUL_5>!
! quantity associated with the field resnonl .010.000000: CAGNBA!
! is not that associated with the parameter PDEFORR: EPSI_R!
! (option: EPEQ_ELNO!
Does anyone have any idea what this means and how you can prevent it?
If I only take a few steps the simulation works.
I have added the whole message file in the attachment.
Best regards
Stefan
