#1 2021-12-08 02:50:21
mu
[SOLVED] heat shock
I've observed an unexpected heat shock in my transient thermal analysis .
Initial temperature of two solids: 30 、10
When time is less than 50 senconds, the max temperature is bigger than 30.
I have tried to use 3D_DIAG modelisation,  but heat shock still exist.
I simulate the model with SolidWorks and I get a correct result without heat shock .
Salome result
SolidWorks result
#2 2021-12-08 10:12:06
RichardS
Re: [SOLVED] heat shock
Hi, for thermal shock applications it is recommended to use 3D_DIAG elements, as its known that full integration elements have the tendency to cause numerical oscillations in the temoerature.
See for ecxample in the training materials here Slide 8:
https hmm/www.code-aster.org/V2/UPLOAD/DOC/Formations/06-thermal_analysis.pdf
Best,
Richard
Richard Szoeke-Schuller
Product Management
www.simscale.com
#3 2021-12-08 10:25:38
mu
SolidWorks result
#4 2021-12-08 10:38:45
mu
Hi, Richard
I have tried to use 3D_DIAG, but heat shock still exist.
Best,
Richard
#5 2021-12-08 11:01:43
RichardS
Ok, t
hen you can try with a smaller time step or fully implicit time integration (theta=1, default is 0.57).
Best,
Richard
Product Management
www.simscale.com
#6 2021-12-09 10:01:10
Volker
Have you already tested a modelling without using LIAISON_MAIL?
I mean you have only one "real" solid and two zones of solid elements...
#7 2021-12-10 08:07:34
mu
Hi, Richard
Thanks for your help that solved my problem!
my solution:
theta: 0.65+ , timestep 0.5s-
RichardS wrote:
Ok, t
Best,
Richard
#8 2021-12-10 08:17:00
mu
Yes, I did.
Just like you said, LIAISON is not necessary, but it is not the problem.
Thank you all the same.
