#1 2021-10-05 04:21:42
CASIO
Barre and POU_D_E mix
In 1D, pin joints(DX,DY,DZ=0) are represented by Barre and rigid joints(DX,DY,DZ,DRX,DRY,DRZ=0) by POU_D_E.
For example, A model in which one of the beams is a pin joint and the other is a rigid joint.
How should we express a structure that conbines these two ?
#2 2021-10-05 08:28:56
Voulet2
Re: Barre and POU_D_E mix
Bonjour.
Have a look of the book of the geat and beloved Jean-Pierre Aubry : framabook.org/beginning-with-code_aster/
Read chapter 7.2 and look how the hinge are treated.
you can model pin by DIST_TR element witk K_TR_D_L stiffness properties. You have to put a 0 stifness where you want rotation.
#3 2021-10-19 19:04:04
CASIO
Thank you for your reply
I made a similar model using Framabook, but I got an error. Do you know what's wrong with the command file?
I succeeded with only POU_D_E, but when I inserted the hinge, I got an error.
