#1 2015-07-28 19:57:08
yoursbh
[Solved] How to run parametric calculations by using as_run
Hello the forum,
I succeed in running a parametric calculation by ASTK interface. However, when I use as_run with the same .export file, an error appears below:
ERREUR A L'INTERPRETATION DANS ACCAS - INTERRUPTION
>> JDC.py : DEBUT RAPPORT
CR phase d'initialisation
   ! <S> Exception utilisateur levee mais pas interceptee.                          !
   ! Les bases sont fermees.                                                        !
   ! Type de l'exception : error                                                    !
   !  soit le fichier n'existe pas, soit c'est une mauvaise version de HDF (utilise !
   ! par MED).        !
fin CR phase d'initialisation
In the .mess file, it shows that the parameter defined in .distr file has not been taken into calculation. But in .export, the option is really activated at the line 8 P distrib oui, and the .distr is well defined (as I used it to run successfully in ASTK interface). So maybe I should add some options when I use as_run for parametric calculation ???
All the related files are attached below.
Thanks for your advices and help !
YoursBH
SALOME-MECA 2015.2 (Salomé 7.6.0 + Code_Aster 11.8 & 12.4) sous Ubuntu 14.04 64bit
#2 2015-07-29 12:29:42
Ivp
Re: [Solved] How to run parametric calculations by using as_run
Try this:
as_run --serv name.export
Best regards
#3 2015-08-05 21:15:15
yoursbh
YES ! It works!
Thanks lvp wink
Ivp wrote:
Try this:
Best regards
#4 2021-10-14 14:49:37
ing.nicola
Same problem.. solved ! thank you Ivp
