#26 2021-10-11 19:24:02
ing.nicola
Re: Questions about singularity version of salome_meca 2021
Maybe I will write a little tutorial on this with your permission.
share and enjoy !
Placing pkginfo.py in ...../aster-src/code_aster/  hg error is solved.
Petsc change often of C API so if you want to use mpi version of code_aster with petsc you have to be up to date.
thanks for the tips . I builded 16.0.8 with PETSC:
singularity run --bind /home:/home -w <full_path_image>.sif shell
in singularity:
export HOST=/home/<folder_sif> ( where placed aster-src and sif image)
export TOOLS="/opt/salome_meca/Salome-V2021-s9/tools"
export ASTER_ROOT_MPI="${TOOLS}/Code_aster_16_0_8_mpi"
export ASTER_ROOT_STD="${TOOLS}/Code_aster_16_0_8_std"
cd ${HOST}/aster-src
./waf_mpi configure --prefix=${ASTER_ROOT_MPI} --install-tests --jobs=8
./waf_mpi build  --jobs=8
./waf_mpi install
./waf_std configure --prefix=${ASTER_ROOT_STD} --install-tests --jobs=8
./waf_std build  --jobs=8
./waf_std install
echo "vers : 16_0_8_mpi:/opt/salome_meca/Salome-V2021-s9/tools/Code_aster_16_0_8_mpi/share/aster" >> ${TOOLS}/Code_aster_frontend-2021001/etc/codeaster/aster
echo "vers : 16_0_8_std:/opt/salome_meca/Salome-V2021-s9/tools/Code_aster_16_0_8_std/share/aster" >> ${TOOLS}/Code_aster_frontend-2021001/etc/codeaster/aster
out of singularity:
singularity run -w --app install <full_path_image>.sif
./name_image
#27 2021-10-11 21:29:04
ing.nicola
file pkginfo.py attached.
#28 2021-10-12 08:45:42
Good morning,
as promised, I repeated the process with the zipped Code Aster sources. Weirdly enough, even with --without-hg everything works now. For the error of yesterday, I blame the hg version of the sources (but I cannot prove that :-) ).
In the evening I will try this on a headless machine (without Graphics Card).
Thank you again, this is great. I summarized this process on my GitHub-page.
https: //github.com/emefff/Code-Aster-MPI-in-Singularity-of-SM2021
#29 2021-10-12 12:11:04
ing.nicola
Great job Mario,
good explaned tutorial.
With pkginfo file , in salome meca list, doesn't appears anymore (0.0.1),  but the version you indicated in the pkginfo list wink
#30 2021-10-12 12:22:06
thank you, all the credit goes out to you. Yes I thought about including that. Maybe I will try in the evening,
#31 2021-10-13 10:43:57
Banned
Dear Mario,
Can you make a Video of Steps to follow in installation.
Your github is perfect but maximum codeaster users are mechanical or civil engineer & not good at computer science, can't understand what is written.
I think, video will be much help.
Also, you mentioned installation without graphic card, lot of students still using codeaster without graphic card on their pc/laptop. much help procedure awaited.
Sameer
#32 2021-10-13 12:08:45
Hello Sameer,
I am also not a software engineer :-)...
Just copy the commands in the tutorial to your terminal. A video wouldn't be more helpful I guess, because it's all just terminal commands.
Headless system: When you built your container successfully, you just copy the container to another system (of course, singularity must be installed on this system). In my case on a headless server, when you start Salome Meca, it automatically recognises if you have a graphics card or not (it enters software rendering mode).
If you log on to this headless system with ssh, then don't forget the X-server. On the client side you then log on with 'ssh -X user@xxx.yyy.zzz.aaa'. The GUI will be forwarded to your terminal then.
Just dig into it, it is worth it!
Hope that helps,
#33 2021-10-18 21:07:12
ing.nicola
with the 16 october 2021 update  ... you can install petsc for 15.4.0 .... ( --disable-petcs is no more necessary ).
The mpi prerequisites have been update.
#34 2021-10-19 10:23:13
Hello Nicola,
now the container is perfect. I updated the recipe on my GitHub (remove space in link...)
I also updated the container that can be downloaded there,
thanks for the info,
#35 2021-10-19 13:52:43
Thanks a lot for this new version with PETSC enabled.
Thanks a lot, Mario, for this modified container with CA-mpi. Also lots of thanks for your step-wise tutorial. It's a great contribution to the community. We had struggled a lot for mpi with earlier CA versions. Decision to use container is really a wise one, I feel.
Presently I am downloading your container and waiting eagerly to try it.
Best regards
#36 2021-10-20 08:15:21
ing.nicola
How to connect with container via ssh ?
Is it possible in visual studio ?
#37 2021-10-20 16:47:44
with an ssh-server and X-server running on a server without graphics card, I just login to this server with 'ssh -X user@xxx.yyy.zzz.aaa' and launch the container there (X11 forwarding must be configured in ssh.conf [?] not sure where exactly at the moment). The GUI is then forwarded to your client. It is a bit sluggish without a graphics card but it works. It also depends a little on your connection (latency).
About visual studio, I do not know.
#38 2021-11-25 11:13:46
jonas loenartz
Hello Mario,
First of all, I wanted to thank you and Ing.nicola for this amazing feat! Your tutorial is very concise, and I was able to install and use the MPI version of SM2021 without any issues so far. It works both, on my local machine as well as on a remote server without a GPU.
I had to run the container with the option  '--soft'  to enable software-rendering, when using it on a remote server, though. Without this option, the application crashed, when opening modules with 3D-rendering control like Paravis or AsterStudy. It did not work automatically for me, so if someone runs into this issue, start the container by using:
./salome_meca-lgpl-2021.0.0-0-20210601-scibian-9 --soft
Greetings,
Jonas
