Bonjour à tous,
Après téléchargement et déploiement du package d'installation du code Aster, j'ai tenté l'installation du code une dizaine de fois, mais il ne va pas jusqu'au bout. Il semble que certains répertoires manquent (EUROPLEXUS_20200; MELIDEFX_V9_4_0...). Voici ci-dessous le message de l'installation.
Pouvez vous me donner des pistes de réparation?
cordialement
Self Extracting salome_meca V2020.0.1_universal_universal Installer
The directory /root/salome_meca/V2020.0.1_universal_universal already exists, install anyway ? [y/N] y
salome_meca is in English, do you want to be in French ? [y/N] : y
Installation of salome_meca V2020.0.1_universal_universal in /root/salome_meca/V2020.0.1_universal_universal ...
All good.
Done
Creating salome_meca application in /root/salome_meca/appli_V2020.0.1_universal_universal ...
Setting for help already set
Setting the language to fr in the preferences file /root/.config/salome/SalomeApprc..universal.universal
Adjusting the file : /root/salome_meca/appli_V2020.0.1_universal_universal/SalomeApp.xml
Warning: the directory /root/salome_meca/V2020.0.1_universal_universal/modules/EUROPLEXUS_20200/lib/salome is in a path variable but does not exist
Warning: the directory /root/salome_meca/V2020.0.1_universal_universal/modules/MELIDEFX_V9_4_0/lib/salome is in a path variable but does not exist
./create_appli.sh: ligne 301: erreur de syntaxe près du symbole inattendu « fi »
./create_appli.sh: ligne 301: `fi'
Adjusting wishexecutable /root/salome_meca/V2020.0.1_universal_universal/tools/Code_aster_frontend-202001/etc/codeaster/profile.sh
Creating symlink in /root/salome_meca/V2020.0.1_universal_universal/tools/Code_aster_stable-1460 : salome -> /root/salome_meca/appli_V2020.0.1_universal_universal/salome
Creating symlink in /root/salome_meca/V2020.0.1_universal_universal/tools/Code_aster_testing-v152_smeca : salome -> /root/salome_meca/appli_V2020.0.1_universal_universal/salome
Final configuration
The message and the solution from Luca Dal'Olio:
Merci pour les informations. Mon hypothèse actuelle est que Salome Meca contient des bibliothèques qui ne sont pas compatibles avec le système d'exploitation.
Un moyen de tester cette hypothèse est de lancer salome avec une commande modifiée pour l'obliger à utiliser les bibliothèques par défaut:
LD_PRELOAD='/usr/$LIB/libstdc++.so.6' DISPLAY=:0 ./salome
The problem is solved; Salome is working well
