On Xubuntu 20.04 :
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413a.export (from astest/zzzz413a.export)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413a.med (from astest/zzzz413a.med)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413b.com1 (from astest/zzzz413b.com1)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413b.comm (from astest/zzzz413b.comm)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413b.export (from astest/zzzz413b.export)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413b.med (from astest/zzzz413b.med)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413c.com1 (from astest/zzzz413c.com1)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413c.comm (from astest/zzzz413c.comm)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413c.export (from astest/zzzz413c.export)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz413c.med (from astest/zzzz413c.med)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz414a.comm (from astest/zzzz414a.comm)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz414a.export (from astest/zzzz414a.export)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz415a.comm (from astest/zzzz415a.comm)
+ install /home/cae/Prgms/aster_15_2_0/15.2/share/aster/tests/zzzz415a.export (from astest/zzzz415a.export)
Waf: Leaving directory `/tmp/install_aster.12758/aster-15.2.0/build/std/release'
+ build the elements catalog elem.1 using installed aster (from cata_ele.ojb)
stdout:
stderr: Traceback (most recent call last):
File "/tmp/install_aster.12758/aster-15.2.0/build/std/release/catalo/fort.1", line 1, in <module>
from code_aster.Commands import DEBUT, MAJ_CATA, FIN
File "/home/cae/Prgms/aster_15_2_0/15.2/lib/aster/code_aster/Commands/__init__.py", line 30, in <module>
from ..Supervis import CO
File "/home/cae/Prgms/aster_15_2_0/15.2/lib/aster/code_aster/Supervis/__init__.py", line 27, in <module>
from .CommandSyntax import CommandSyntax
File "/home/cae/Prgms/aster_15_2_0/15.2/lib/aster/code_aster/Supervis/CommandSyntax.py", line 61, in <module>
from ..Objects import DataStructure
File "/home/cae/Prgms/aster_15_2_0/15.2/lib/aster/code_aster/Objects/__init__.py", line 27, in <module>
from libaster import *
ImportError: /home/cae/Prgms/aster_15_2_0/15.2/lib/aster/libbibfor.so: undefined symbol: metis_setdefaultoptions_
To run manually, use:
export LD_LIBRARY_PATH="/home/cae/Prgms/aster_15_2_0/15.2/lib/aster:/home/cae/Prgms/aster_15_2_0/public/hdf5-1.10.3/lib:/home/cae/Prgms/aster_15_2_0/public/med-4.0.0/lib:/home/cae/Prgms/aster_15_2_0/public/metis-5.1.0/lib:/home/cae/Prgms/aster_15_2_0/public/scotch-6.0.4/lib:/home/cae/Prgms/aster_15_2_0/public/mumps-5.2.1/lib:/home/cae/Prgms/aster_15_2_0/public/tfel-3.2.1/lib:/usr/lib/x86_64-linux-gnu:/usr/lib/python3.8/config-3.8d-x86_64-linux-gnu:/home/cae/Prgms/OpenFOAM9/ThirdParty-9/platforms/linux64Gcc/gperftools-svn/lib:/home/cae/Prgms/OpenFOAM9/ThirdParty-9/platforms/linux64Gcc/ParaView-5.6.3/lib:/home/cae/Prgms/OpenFOAM9/OpenFOAM-9/platforms/linux64GccDPInt32Debug/lib/openmpi-system:/home/cae/Prgms/OpenFOAM9/ThirdParty-9/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/x86_64-linux-gnu/openmpi/lib:/home/cae/OpenFOAM/cae-9/platforms/linux64GccDPInt32Debug/lib:/home/cae/Prgms/OpenFOAM9/site/9/platforms/linux64GccDPInt32Debug/lib:/home/cae/Prgms/OpenFOAM9/OpenFOAM-9/platforms/linux64GccDPInt32Debug/lib:/home/cae/Prgms/OpenFOAM9/ThirdParty-9/platforms/linux64GccDPInt32/lib:/home/cae/Prgms/OpenFOAM9/OpenFOAM-9/platforms/linux64GccDPInt32Debug/lib/dummy:/home/cae/Prgms/same_meca_2020/V2020.0.1_universal_universal/prerequisites/Python-365/lib:/home/cae/Scrivania/aster-full-src-15.2.0:/usr:/usr/lib/gcc/x86_64-linux-gnu/9:/usr/lib/python3.8/config-3.8d-x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/home/cae/Prgms/aster_15_2_0/public/tfel-3.2.1/lib:/home/cae/Prgms/aster_15_2_0/public/tfel-3.2.1"
export PYTHONPATH="/home/cae/Prgms/aster_15_2_0/15.2/lib/aster:/usr/local/lib/python3.8/dist-packages:/home/cae/Prgms/aster_15_2_0/lib/python3.8/site-packages:/home/cae/Prgms/aster_15_2_0/public/tfel-3.2.1/lib/python3.8/site-packages:/home/cae/Prgms/same_meca_2020/V2020.0.1_universal_universal/tools/Code_aster_frontend-202001/lib/python3.6/site-packages:/home/cae/Prgms/MyOp:/home/cae/Scrivania/aster-full-src-15.2.0:/home/cae/Prgms/aster_15_2_0/lib/python3.8/site-packages:/home/cae/Prgms/aster_15_2_0/public/tfel-3.2.1/lib/python3.8/site-packages"
/usr/bin/python3 /tmp/install_aster.12758/aster-15.2.0/build/std/release/catalo/fort.1 --memory=4096
Command '/usr/bin/python3 /tmp/install_aster.12758/aster-15.2.0/build/std/release/catalo/fort.1 --memory=4096' returned 1
EXIT_COMMAND_12758_00000094=1
