#1 2021-07-23 03:34:03
xyg1996
[SOLVED]'LIBPATH_MFRONT' 、 'LIBPATH_SCOTCH' not yet defined
Dear code-aster users and developers:
I was trying install code-aster 14.6 on my Unbuntu20.04.1. I prepared all the prerequistes. However, I got following failed message. It seems the MFront and scotch in \SRC are not installed right. What can I do?
>>> Extraction <<<
entering directory '/tmp/install_tfel.343143'
Extracting tfel-3.2.1-1.tar.gz...                                      [  OK  ]
 --- 7044 files extracted
leaving directory '/tmp/install_tfel.343143'
>>> Configuration <<<
entering directory '/tmp/install_tfel.343143/tfel-3.2.1'
Command line : mkdir build ; cd build ; cmake ..   -DCMAKE_BUILD_TYPE=Release   -DTFEL_SVN_REVISION=3.2.1 -DTFEL_APPEND_VERSION=3.2.1   -DCMAKE_Fortran_COMPILER=/usr/bin/gfortran   -Dlocal-castem-header=ON -Denable-fortran=OFF   -Denable-broken-boost-python-module-visibility-handling=ON   -Denable-python-bindings=ON   -Denable-cyrano=ON -Denable-aster=ON   -Ddisable-reference-doc=ON -Ddisable-website=ON   -Denable-portable-build=OFF   -DPython_ADDITIONAL_VERSIONS=3.8 -Denable-python=ON   -DPYTHON_EXECUTABLE:FILEPATH=/usr/bin/python3   -DPYTHON_LIBRARY:FILEPATH=/usr/lib/python3.8/config-3.8-x86_64-linux-gnu/libpython3.8.so   -DPYTHON_INCLUDE_DIR:PATH=/usr/include/python3.8   -DCMAKE_INSTALL_PREFIX=/home/xiangyanggang/Software/code-aster-obj/public/tfel-3.2.1
configure tfel installation...
Command output :
configure tfel installation...                                         [FAILED]
Exit code : 1
CMake Warning (dev) in CMakeLists.txt:
 No project() command is present.  The top-level CMakeLists.txt file must
 contain a literal, direct call to the project() command.  Add a line of
 code such as
   project(ProjectName)
 near the top of the file, but after cmake_minimum_required().
 CMake is pretending there is a "project(Project)" command on the first
 line.
This warning is for project developers.  Use -Wno-dev to suppress it.
Checking for dependencies and required variables for 'aster'...        [  OK  ]
Installation of   : aster 14.6.0
  Code_Aster finite element method solver.
Archive filename  : aster-14.6.0
Destination       : /home/xiangyanggang/Software/code-aster-obj
Working directory : /tmp/install_aster.343143
Filling cache...
'LIBPATH_MFRONT' not yet defined
        [FAILED]
Exit code : 255
 *** Exception raised : unavailable variables
    Problem with : LIBPATH_MFRONT, LIBPATH_SCOTCH
     SUMMARY OF INSTALLATION
 Installation of   : hdf5 1.10.3
Destination       : /home/xiangyanggang/Software/code-aster-obj/public/hdf5-1.10.3
Elapsed time      : 111.39 s
        [  OK  ]
 Installation of   : med 4.0.0
Destination       : /home/xiangyanggang/Software/code-aster-obj/public/med-4.0.0
Elapsed time      : 119.47 s
        [  OK  ]
 Installation of   : astk 2020.0
Destination       : /home/xiangyanggang/Software/code-aster-obj/lib/python3.8/site-packages
Elapsed time      : 1.93 s
        [  OK  ]
 Installation of   : metis 5.1.0
Destination       : /home/xiangyanggang/Software/code-aster-obj/public/metis-5.1.0
Elapsed time      : 193.49 s
        [  OK  ]
 Installation of   : tfel 3.2.1
Destination       : /home/xiangyanggang/Software/code-aster-obj/public/tfel-3.2.1
Elapsed time      : 9.51 s
*** Exception None raised : None
See detailed traceback in the logfile
        [FAILED]
Exit code : 4
 Installation of   : mumps 5.1.2
Destination       : /home/xiangyanggang/Software/code-aster-obj/public/mumps-5.1.2
Elapsed time      : 124.36 s
        [  OK  ]
 Installation of   : homard 11.12
Destination       : /home/xiangyanggang/Software/code-aster-obj/public/homard-11.12
Elapsed time      : 22.45 s
        [  OK  ]
Elapsed time      : 0.01 s
        [ SKIP ]
 Installation of   : Code_Aster + 8 of its prerequisites
Elapsed time      : 594.07 s
        [  OK  ]
#2 2021-08-10 09:56:34
Irvise
Re: [SOLVED]'LIBPATH_MFRONT' 、 'LIBPATH_SCOTCH' not yet defined
Hi Xiangyang,
After taking a look into the log, I think the problem with TFEL/MFRONT is that it is missing some dependencies:
-- Could NOT find Boost (missing: Boost_INCLUDE_DIR python-py38 numpy-py38) (Required is at least version "1.36.0")
-- Trying to find libboost_python38
-- Could NOT find Boost (missing: Boost_INCLUDE_DIR python38 numpy38) (Required is at least version "1.36.0")
-- Trying to find libboost_python-py3
CMake Warning at /usr/share/cmake-3.16/Modules/FindBoost.cmake:2020 (message):
 No header defined for python-py3; skipping header check (note: header-only
 libraries have no designated component)
Call Stack (most recent call first):
 CMakeLists.txt:324 (find_package)
 No header defined for numpy-py3; skipping header check (note: header-only
-- Could NOT find Boost (missing: Boost_INCLUDE_DIR python-py3 numpy-py3) (Required is at least version "1.36.0")
-- Could NOT find Boost (missing: Boost_INCLUDE_DIR python3 numpy3) (Required is at least version "1.36.0")
-- Could NOT find Boost (missing: Boost_INCLUDE_DIR python numpy) (Required is at least version "1.36.0")
CMake Error at CMakeLists.txt:366 (message):
 Boost python libraries not found.
This is at the bottom of the failure of TFEL.
Since you are using Ubuntu, the -devel packages are not installed by default. Meaning that CA seems to be looking at the -devel packages for boost and boot+python.. Could you search for these packages, install them and see if it works?
Fernando Oleo Blanco
#3 2021-08-10 14:15:27
xyg1996
Irvise wrote:
Hi Xiangyang,
Thank you very much! It works!
