#1 2021-04-13 18:57:32
scimulate
Connecting MUMPS (Parallel) to Code_Aster
I'm able to compile Code_Aster 14.6, and all of its included sub-packages, on Ubuntu 20.04, but MUMPS compiles/installs a sequential (non-parallel) version by default.
From reading, it appears that I need to compile the parallel version of MUMPS first, then modify setup.cfg before compiling the full package. I'm able to compile MUMPS parallel version without issue (tested with the included MUMPS samples under ./examples/), and I copied the entire ./mumps-5.1.2/ folder to /opt/aster/public/ (to keep my entire Code_Aster installation in one location). Next, I modified the bottom of setup.cfg:
_install_mumps = False
HOME_MUMPS='/opt/aster/public/mumps-5.1.2'
However, when I load up astk with a project (one that previously ran sequentially without issue), I now receive an error message that MUMPS isn't installed.
JDC.py : ERREUR A L'EXECUTION - INTERRUPTION
>> JDC.py : DEBUT RAPPORT
CR d'execution de JDC en MIXTE
   ! <S> Exception utilisateur levee mais pas interceptee.                            !
   ! Les bases sont fermees.                                                          !
   ! Type de l'exception : error                                                      !
   ! Le solveur "MUMPS" n'est pas installé dans cette version de Code_Aster.          !
   ! Conseil : Vérifiez que vous avez sélectionné la bonne version de Code_Aster.     !
   !           Attention, certains solveurs ne sont disponibles que dans les versions !
   ! parallèles de Code_Aster.                                                        !
fin CR d'execution de JDC en MIXTE
>> JDC.py : FIN RAPPORT
EXECUTION_CODE_ASTER_EXIT_412399-system76=1
 <I>_EXIT_CODE = 1
Can someone please point out what I'm missing? Thanks!
#2 2021-07-08 07:15:46
massimobrivio
Re: Connecting MUMPS (Parallel) to Code_Aster
Hello, I’m also interested in this since i tried the same and i also failed. Did you manage to do this?
#3 2021-07-08 08:47:48
I was able to build CA 14.6 MPI (also with PETSc) by following this great description:
h_ttps://hitoricae.com/2020/10/31/code_aster-14-6-parallel-version-with-petsc/
There is a slight error in the end though. If I remember correctly, a '/' is missing in the line before '$ASTER_ROOT' (without the ' of course..):
$ ./waf configure --use-config-dir=$ASTER_ROOT/14.6/share/aster --use-config=Ubuntu_gnu_mpi --prefix=$ASTER_ROOT/PAR14.6MUPT
I followed the description EXACTLY (versions and order have to be exact...etc.), I also tried 20.04LTS, but couldn't install superlu correctly from the Ubuntu repos. Maybe this is possible with the now updated U20.04.
Hope it helps,
