#1 2021-06-11 15:08:11
kadred
can i use xfem without define initial crack ?
Is it possible to use XFEM without defining initial crack ?
In my model i dont have an initial crack, i would like to use xfem to predicts the crack initiation sites considering the applied boundary conditions. Is it possible ?
Thank you in advance for any help.
#2 2021-06-12 04:21:13
GXA_William
Re: can i use xfem without define initial crack ?
Greetings Kadred.
The simple answer is yes.  In fact, XFEM allows one to use a "sane" mesh, without directly modeling the crack.
-William
#3 2021-06-14 15:36:02
kadred
thanks for your answer.
If it possible, so what do i have to do in the step "DEFI_FISS":
"FISS=DEFI_FISS_XFEM(MAILLAGE=MAILLA,
                                          TYPE_DISCONTINUITE = / 'FISSURE', [DEFAULT]
        / 'INTERFACE'
                                          DEFI_FISS=_F()
#4 Yesterday 05:42:21
GXA_William
Hello Kadred.
One suggestion is to look at test case SSLV315.
-William
