#1 2021-06-09 10:33:54
LouisB
Split Surface
I have a quick question regarding the geometry module.
Is there a command in the Geometry module to split a Surface into Multiple surface ?
In ANSYS it is the "Fraction" command where we just have to enter the distance from a selected point/edge (see the attached screen shot) but I don't find the equivalent in Salome Meca.
LB
#2 2021-06-09 11:18:28
Re: Split Surface
Hello Louis,
I do not know of such a command in Salome. However, it is quite easy and should not take more than 5 minutes:
1) create points on edges (with 'by length', though also other possibilities)
2) connect them with lines
3) do a partition of your body with these lines
4) voila--> segmented face
See the screenshots attached in chronological order,
EDIT: the purpose is to create surface groups and to mesh the differently, right?
#3 2021-06-09 14:32:12
LouisB
Re: Split Surface
Thank you for the tips.
No the purpose is to split a surface and put some beams (with differents I beams sections) on each line that I create (see the attached picture).
LB
