#1 2021-05-26 05:50:32
Igor Barcelos
Dome analysis
Hi, for the past few days I have been trying to perform a dome analysis with only the self-weight applied but I'm facing some problems. I'm using DKT element since I'm keeping QUAD4 elements. Up to this point, I have two main questions:
1) I have quite strange results when using the _ELNO field. The stress field presents no pattern and I really don't know why. This problem has been presented by Cyprien in the below video (minute 31:40) but he did not explain the reason. Any ideas? I'm also attaching an image.
https:// www. youtube.com/watch?v=7p5mQuJIZdI&ab_channel=CyprienRusu
2) When I set _ELGA results I start to have some results that at least reminds me of usual dome behavior (image attached). The problem here is that these results are in the global coordinate systems and when I try to set the cylindrical coordinate I get an error.
RESU=CALC_CHAMP(reuse =RESU,
                MODELE = MO,
                RESULTAT =RESU,
                CONTRAINTE = ('SIGM_ELNO','SIEF_ELGA','SIGM_ELGA'),
                CRITERES = 'SIEQ_ELGA',),
RESU1=MODI_REPERE(RESULTAT = RESU,
                MODI_CHAM = (_F( NOM_CHAM = 'SIGM_ELGA',
                                NOM_CMP sad'SXX','SYY','SXY','SZZ',),
                                TYPE_CHAM = 'TENS_2D',),),
                                REPERE = 'CYLINDRIQUE',
                                AFFE = _F(ORIGINE = (0.0, 0.0, 0.0,),
                                         AXE_Z = (0.0, 0.0, 1.0,),),)
Error : Le TYPE_ELEMENT MEBODKT  ne sait pas encore calculer l'option:  COOR_ELGA.
I'm attaching all the necessary files. Could you please provide me some ideas?
I really appreciate it. Thank you all.
#2 2021-05-26 05:51:58
Igor Barcelos
Re: Dome analysis
Files here.
#3 2021-05-26 14:40:21
Banned
Re: Dome analysis
below info will help you.
refer page 89,90,91,92,93 of code_asterbook-jp_aubry-20190129.pdf book
stat=CALC_CHAMP (
reuse =stat , RESULTAT=stat ,
CONTRAINTE = (
’SIEF_ELNO’ ,
’SIPO_ELNO’ ,
’SIPM_ELNO’ ,
’SIGM_ELNO’ ,
FORCE = ( ’REAC_NODA’ ) ,
#U4.85.01
stat2=POST_CHAMP (
RESULTAT=stat ,
GROUP_MA = ( ’panel’ , ) ,
EXTR_COQUE=_F (
NUME_COUCHE=1 ,
NIVE_COUCHE=’SUP’ ,
NOM_CHAM = ( ’SIGM_ELNO’ , ) ,
statsup=CALC_CHAMP (
RESULTAT=stat2 ,
CRITERES = ( ’SIEQ_ELNO’ , ’SIEQ_NOEU’ , ) ,
#4 2021-06-05 19:30:27
Igor Barcelos
Re: Dome analysis
Thanks a lot, Sameer, that really solved the problem.
