#1 2021-05-17 14:51:27
amartin
[Solved] Issue launching Salome-Meca 2020 on ubuntu 18.04
I just installed Salome-Meca on ubuntu 18.04. When launching, I have an issue :
inside europlexus set env...
Searching Naming Service  +omniNames: (0) 2021-05-17 15:39:42.461612: -ORBendPoint option overriding default endpoint.
 found in 0.1 seconds
Searching /Kernel/Session in Naming Service  +Warning, no type found for resource "localhost", using default value "single_machine"
++Warning: this type (Study,objref) already exists, it will be ignored.
 found in 1.5 seconds
Start SALOME, elapsed time :   1.8 seconds
th. 139961223066176 - Trace /home/A34370/smeca/yamm_build/V2020.0.1_universal_build/V2020_nopackage_universal/modules/src/GUI/src/LightApp/LightApp_Application.cxx [807] :
     Warning: icon for Calculator is not found!
     Using the default icon.
*** Abort *** an exception was raised, but no catch was found.
... The exception is:SIGSEGV 'segmentation violation' detected. Address 8
There seems to be a problem during the launch (the salome-meca logo appears then disappears).
Any idea ?
Adrien
#2 2021-05-18 13:35:36
amartin
Re: [Solved] Issue launching Salome-Meca 2020 on ubuntu 18.04
the problem came from the graphic card.
Adrien
#3 2021-05-22 02:56:56
sihaqqi
how can we avoid this problem
#4 2021-08-09 17:06:14
msh
amartin wrote:
Adrien
Hello, Adrien! Please, consult, how you fix this problem?
#5 2021-08-10 14:52:50
The following may help, although I am not sure:
Please try the point No 9 in post #20 of ____/forum2/viewtopic.php?id=24883.
Best wishes
#6 2021-08-30 19:04:53
msh
@sb1966, thanks you, but I can't resolve my problems from topic named "Can't run SM v. 2020.0.1-1-un. in Debian Linux v.9-based OS" and after all I was choose SM v. 2019.3, because I don't have the same problems with SM v. 2019.3.
#7 2021-08-31 19:58:32
Dear msh,
Thanks for your info.
I think, SM 2020 version has been troublesome for many users including some experts. There are Forum posts requesting newer release of SM 2020 and people have reverted back to 2019.0.3 for the time being. I hope it will be resolved soon. I posted a question to the developers regarding this (viewtopic.php?id=25788); however, it has not attracted any reply so far.
Presently I am also using SM 2019.0.3  in Ubuntu 18.04. I think, it is quite good a version..
Another reason to stick to Ubuntu 18.04 is that Ubuntu 20.04 has some bug related to $\LaTeX$ also. This has delayed upgrading to Ubuntu 20.04 for many users, including me. neutral
Best regards.
