#1 2021-03-01 12:29:51
cacciatorino
[Mesh] error while trying to mesh an object
I'm trying to create the mesh of an object but this error arises when I select the criteria to the meshing process:
 Salome Exception : /usr/lib/x86_64-linux-gnu/liblapack.so.3: undefined symbol: strtrs_UNU_parallel
Salome 2020.0 and Ubuntu 20.10.
Any hint? I guess it was due to the last ubuntu upgrade (20.04--> 20.10) but I'm not sure.
#2 2021-03-03 17:34:39
rmoortgat
Re: [Mesh] error while trying to mesh an object
Probably. Ubuntu 20.10 broke my installation too.
Roger
#3 2021-03-12 19:48:53
Ali
I have the same problem with both 2019 and 2020 versions of salome meca with ubuntu 20.10
#4 2021-03-26 17:16:25
VonPire
I also have the same problem with SalomeMeca2020 and Ubuntu 20.10 (Groovy Gorilla).
I tried to make symbolic link from my system liblapack.so.3 to salomes prequistic folder, but it didn't help to the problem:
ln -sf /lib/x86_64-linux-gnu/liblapack.so.3 home/username/salome_meca/V2020.0.1_universal_universal/prerequisites/Lapack-380/lib/liblapack.so.3
I'm not good at using Ubuntu so this was just a blind attempt.
Has anyone managed to solve this problem ?
VonPire
#5 2021-05-07 21:45:02
RuiS
Hi everyone,
Got the same error using Salome-Meca 2020 on Ubuntu 21.04.
The same error message appear to me, as in the previous posts.
Simply cannot mesh my objects, even while following tutorials and doing things exactly as shown.
I really have no clue what this is about.
So, if someone has any hint on the issue, I would be glad to ear about it. big_smile
Thank you for your time.
RuiS
#6 2021-09-04 13:27:49
av
I solved the problem with the syslink:
cd $INSTALLATION_PATH$/salome_meca/V2020.0.1_universal_universal/prerequisites/debianForSalome/lib
ln -s /usr/lib/x86_64-linux-gnu/lapack/liblapack.so.3 liblapack.so.3
