#51 2019-10-09 21:21:31
tianyikillua
Re: Code_Aster inside a Docker container available for everyone
ok, now the 14.4 version (sequential and parallel) is also available as a Docker image, see the github page.
quay.io/tianyikillua/code_aster
Some issues with petsc
Also case tests are to be re-run. If someone could report on github it would be useful.
The old 13.6 version is available as quay.io/tianyikillua/code_aster:v13
#52 2020-03-03 15:42:40
mvanwaveren
You mention:
Is the parallel version an MPI or an OpenMP version?
#53 2020-03-07 11:36:59
tianyikillua
mpi + openmp
#54 2020-05-06 11:46:07
Dear Tianyi,
first of all, thank you for this, this is really great stuff. I tried to compile the parallel version and did not succeed (I finally gave up, none of the online tutorials is 100% correct), so this is a way out for all users who are not software engineers to use the MPI version. Under Linux it seems to be VERY fast.
However, I have one question: can I use this docker on more than one node (nodes are connected via Infiniband)? Or are there modifications to the docker necessary? I cannot test this at the moment, thus my question. There is also something called 'docker swarm' could this be a possibility to run it on more than one node? As you have guessed, I am not a software engineer, so these might be dumb questions....
Thank you anyway,
#55 2020-07-07 01:16:40
llionevans
mf wrote:
Dear Tianyi,
Thank you anyway,
One of the things we're looking at is using this with singularity instead of docker (but we're still having issues building the container). The reason for this is that singularity should be more appropriate for HPC vs docker.
Once we've been able to build the container we will test and report back on our results.
#56 2021-02-11 18:42:40
alealbanesi
I'm trying to run cases in parallel, and I would like to ask for the correct configuration of "mpi_nbcpu" and "ncpus" variables for a multi-core CPU with one socket. I have an CPU with the I7-8700K, it has 6 cores with 2 threads per core (12 threads total) on one socket
I've successfully installed docker following tianyikillua instructions in GitHUB, all tests run Ok in parallel or sequential mode.
I've been doing some tests with some cases that need approximately 8 hours to compute on a single core using MUMPS. So far, the best configuration tested has "mpi_nbcpu = 3" and "ncpus = 2", and total computational time is 6 hours approximately with MUMPS.
Does anyone have other thoughts about this? Perhaps the limit is the single socket?
Thank you in advance,
Alejandro
#57 2021-02-11 20:12:06
you are right, this does not seem to be a huge gain. From my experience, your numbers are good for this CPU (mpi_nbcpu=3/ ncpus=2). Turning Hyperthreading off also helps (your tasks do not get interrupted so often by other tasks if HT=off). It also depends on the problem itself. I am not sure now, but I think I had a thermal only calculation once, where the benefit though MPI was also very low. From my experience with larger problems (5-6 M DOFs), doubling the number of cores makes it ~1.5 times faster (but uses more RAM overall). If the problem is too small in DOFs, the benefit will also be smaller. Other factors may be, but I don't  think it will help much, unless your problem is really big on more than one CPU:
-) MATR_DISTRIBUEE='OUI' in STAT_NON_LINE
-) DISTRIBUTION=_F(METHODE='SOUS_DOMAINE',
                             PARTITIONNEUR='METIS'),
    or similar in AFFE_MODELE.
Take care that your calculation does not run OUT_OF_CORE, it will be very slow then (insufficient RAM).
h ttps://www.code-aster.org/doc/default/en/man_u/u2/u2.08.06.pdf
#58 2021-02-11 20:30:24
alealbanesi
Great Mario, thank you for your reply.
I will try those options in AFFE_MODELE, and see what happens.
Kind regards,
Alejandro
#59 2021-02-12 14:35:20
Hello again,
something else just came to my mind: if your CPU is strongly affected by the Spectre and Meltdown mitigations and security is not an issue (perhaps you are behind a strong and up-to-date firewall) you may think about turning these mitigations OFF. It may also boost your performance a bit (depends on CPU though, some tasks are 10-50% slower with mitigations ON). This is especially easy under Linux, with Windows I do not know how to turn these off.
#60 2021-02-25 21:06:08
alealbanesi
Thanks for the help Mario. Things are working ok now. I had a mechanical problem that needed 3 hours and 8 minutes for the solution when running on a single core of my CPU.
In parallel, things are much better:
* When using docker, and configuring (mpi_nbcpu=3/ ncpus=2), 57 minutes are needed for the solution.
* When using docker, configuring (mpi_nbcpu=3/ ncpus=2), and following your advice on (MATR_DISTRIBUEE='OUI' in STAT_NON_LINE) and (PARTITIONNEUR='METIS' in AFFE_MODELE.), 47 minutes are needed for the solution.
In my opinion, the scalability level in this parallel problem is great.  Of course, the "mpi_nbcpu" and "ncpus" parameters depend on the CPU type. Cheers,
Alejandro
#61 2021-04-09 14:25:39
abbas
tianyikillua wrote:
Could you please remove the left and right brackets?
docker run -ti --rm -e DISPLAY=192.168.44.176:0 -v %cd%:/home/aster/shared -w /home/aster/shared quay.io/tianyikillua/code_aster
Great work Tianyi!
I have the same problem when running astk. I am running ubuntu 20 and I'm using wired connection. I tried different IPs but cannot get the visual astk running. I get the error
application-specific initialization failed: couldn't connect to display "my ip address:0"
Error in startup script: invalid command name "wm"
    while executing
"wm withdraw ."
if I export the DISPLAY to an IP like praful's case (192.168.44.176), astk commands runs without error But no astk window is shown (see attached)
#62 2021-05-03 09:12:33
Dear Tianyi!
I don't like to pose that question, but what are there any plans of updating your Docker with the upcoming stable 15.2 (?) version of Code Aster?  :-) What are the chances? :-)
Don't get me wrong, in the meantime I managed to compile and build 14.6 with MPI and PETSC, but I only now understand how difficult creating a Docker Container is in reality. So, I gave up on building a Docker in the meantime.
#63 2021-05-06 21:16:23
#64 2021-05-07 07:02:12
Dear AsterO'dactyle,
I know about that, I participated a little bit (testing). It is still SalomeMeca, but I know that plans for a CA-MPI version in a singularity-containers are on the horizon. What I do not know is, how far they are. Though SM runs flawlessly in singularity,
