#1 2021-05-05 00:34:05
windy_concrete
[SOLVED] CALC_CHAMP cannot read from 2nd list of EVOL_NOLI
Hi - the short solution to this problem is that in AsterStudy of SalomeMeca for Windows (Simulease build) 9.3.0 (which is CodeAster 14.4) you cannot perform DETRUIR on your load functions before performing CALC_CHAMP on your results (e.g. EVOL_NOLI / STAT_NON_LINE) which result from those load functions. This is what I was doing, and this is why I had my problem. So, do not do this and you may be fine. Below you may find some input from others that will explain more and maybe help more. - Kirk
Hi - I posted about this before and I am afraid I did not describe the problem correctly. My issue is that of two indexed sets of EVOL_NOLI my CALC_CHAMP calls can only access the first set. The database listing printout after completion of all shows both sets exist. Like this:
Concepts de la base (message file)  wrote:
Concepts de la base: G
    Nom       Type                 Taille (Mo)         Nombre      Nombre de
                                                     d'objets       segments
    TOTAL                               117.24            665            967
    mesh       MAILLAGE_SDASTER           0.99             36             67
    model      MODELE_SDASTER             0.50              8             13
    modout     MODELE_SDASTER             0.47              8             13
    elempro0   CARA_ELEM                  8.53             35             65
    elempro1   CARA_ELEM                  0.41             10             15
    rsvrt_1    EVOL_NOLI                 27.22            120            154
    FNRX       EVOL_NOLI                  0.01             11             15
    rshrz_0    EVOL_NOLI                 11.98             78             97
    rsvrt_0    EVOL_NOLI                 27.22            120            154
    conc       MATER_SDASTER              0.00              5              5
    gspring    MATER_SDASTER              0.00              8              8
    wkspring   MATER_SDASTER              0.00              5              5
    fieldmat   CHAM_MATER                 0.06              6             11
    VGUIDE     CHAR_MECA                  0.32             23             43
    GRAVIT     CHAR_MECA                  0.02              8             13
    SOMNGW     CHAR_MECA                  0.05              8             13
    SOM_GW     CHAR_MECA                  0.05              8             13
    SOW_GW     CHAR_MECA                  0.05              8             13
    PTBOL_     CHAR_MECA                  0.05              8             13
    BUOY__     CHAR_MECA                  0.05              8             13
    LIST_V     LISTR8_SDASTER             0.00              6              6
    LIST_H     LISTR8_SDASTER             0.00              6              6
    *****_H     LIST_INST                  0.00              9              9
    rshrz_1    EVOL_NOLI                 11.98             78             97
    &FOZERO                               0.00              2              2
    &&_NUM_C                              0.00              1              1
    &CATA.AC                              0.00              2              4
    &CATA.CL                              0.60              1              3
    &CATA.GD                              0.14              4             11
    &CATA.ME                              0.20              2              4
    &CATA.OP                              0.30              4             19
    &CATA.PH                              0.00              1              1
    &CATA.PR                              0.00              2              4
    &CATA.TE                             26.03             17             42
    &CATA.TH                              0.01              2              4
    &CATA.TM                              0.01              7             11
But, like I said, I only seem to be able to get rsvrt_# since calls of CALC_CHAMP with RESULTAT="rshrz_0" return the following error:
   ! <S> Exception user raised but not interceptee.                               !
   ! The bases are fermees.                                                       !
   ! Type of the exception: error                                                 !
   ! Program error.                                                               !
   ! Condition not met:                                                           !
   !     .false.        !
   ! File        !
   ! /home/A21173/smeca/yamm_build/V2019.0.3_pub_build/V2019_universal/tools/src/ !
   ! Code_aster_stable-v144_smeca/bibfor/utilitai/dismoi.F90,                     !
   ! line 185        !
Would anyone have insight into this problem with obtaining results from two different EVOL_NOLI sets (CALC_CHAMP)? Thank you!
Kirk Morgan
PS I have attached the problem message file.
MS Structural Engineering and 15 years in shore-based wind turbine foundations. Code_Aster / Salome-Meca newbie.
#2 2021-05-06 21:07:56
Re: [SOLVED] CALC_CHAMP cannot read from 2nd list of EVOL_NOLI
This is a bug that seems to me to have been corrected recently.
An idea: to avoid destroying the loads before CALC_CHAMP.
#3 2021-05-06 22:27:28
windy_concrete
Thank you so very much for responding!
Yes, I seem to have stumbled on the same idea to not destroy loads prior to CALC_CHAMP but I cannot understand why this works.
How, can I ask, did you get your idea?
Is the bug (with CALC_CHAMP) that you say was fixed? Is this documented? How could I find it?
I have a different load function for all my load cases and what seems to be is that I need to completely post process each analysis (use CALC_CHAMP, etc.) before I go onto the next result. I think I can live with this, I just can't understand it.
Thank you again!
#4 2021-05-10 21:12:55
You need loads to compute REAC_NODA.
But in your version, we ask for loads BEFORE knowing if you're computing REAC_NODA ! It's useless
