#1 2021-03-22 08:57:14
Igor Barcelos
[SOLVED] EXTR_TABLE does not work
Hi everyone!
For the last two days, I have been struggling in using EXTR_TABLE to access the Code_Aster concepts in the python environment.  I have tried with the Linux and windows CA  version and I get the same error.
" AttributeError: 'tuple' object has no attribute 'EXTR_TABLE'   "
I'm attaching all the necessary files of my model, which is quite simple: bending of a simply supported beam.
Do you have any ideas on how to solve this problem?
Thank you!
#2 2021-03-22 09:22:13
Re: [SOLVED] EXTR_TABLE does not work
your object TBL is a tuple. If you do TBL[0].EXTR_TABLE(), it works. Nevertheless i don't know why it is a tuple...
#3 2021-03-22 11:22:23
GPSalachs
You could also try to
TABLE = TAB.EXTR_ΤΑBLE()
Values = TABLE.valeurs()['PARAM']
If i remember correctly it is found in the documentation regarding python objects.
#4 2021-03-22 12:33:42
Igor Barcelos
konyaro wrote:
your object TBL is a tuple. If you do TBL[0].EXTR_TABLE(), it works. Nevertheless, i don't know why it is a tuple...
Big thanks, Konyaro. That solved the problem.. although is not clear why my object is a tuple.
@GPSalachs The syntax presented in the documentation about python objects did not work for me in this case. Don't know why.
#5 2021-05-03 17:47:09
windy_concrete
I had this issue in CodeAster for Windows. Today in Python script I executed print(type(TABLE)) of Konyaro's output object. This directed me to the Utilitai.py package and the table.py script therein. On examination of file "table.py" I was able to see the main attributes, self.rows, self.type, etc. for the entries in table class.
The bottom line here is that you get an object from POST_RELEV_T that is a legacy CodeAster object. (object = POST_RELEV_T...)
Then you convert this object and assign it as object2 = object.EXTR_TABLE()
This 'object2' is now of the type Utilitai.TABLE.table and you can access it with dictionary calls to TABLE.rows[#]['param']
If this is not clear and more is needed please post reply and I will try to help more.
Kirk
MS Structural Engineering and 15 years in shore-based wind turbine foundations. Code_Aster / Salome-Meca newbie.
