#1 2020-11-26 20:46:42
Markone
Installation on Ubuntu 20.04 - Virtual Machine - Solution not working
Hi All,
I am trying to install Salome-Meca on a 20.04 Ubuntu virtual machine, and I got the error below upon extracting.
I then found the solution by user sb1966 on June the 25th, 2020, at //www.code-aster.org/forum2/viewtopic.php?id=24883.
I perform the steps up to 5, but no create_appl.sh file is created at all, and I cannot proceed.
Are there any obvious steps in the aforementioned solution I might be overlooking? I am an absolute Linux / Code Aster beginner, thanks a lot
Marco
Error after first try
marco@marco-VirtualBox:~/Downloads$ tar xvf salome_meca-2019.0.3-1-universal.tgz && ./salome_meca-2019.0.3-1-universal.run
Self Extracting salome_meca V2019.0.3_universal Installer
Enter the salome_meca install directory [default=/home/marco/salome_meca] : salome_meca is in English, do you want to be in French ? [y/N] : n
Installation of salome_meca V2019.0.3_universal in /home/marco/salome_meca/V2019.0.3_universal ...
All good.
Done
Creating salome_meca application in /home/marco/salome_meca/appli_V2019.0.3_universal ...
Setting for help already set
python: can't open file '/salomemeca_custom_appli.py': [Errno 2] No such file or directory
To run the application:
$ /home/marco/salome_meca/appli_V2019.0.3_universal/salome
Adjusting wishexecutable /home/marco/salome_meca/V2019.0.3_universal/tools/Code_aster_frontend-20190/etc/codeaster/profile.sh
Final configuration
#2 2020-12-14 13:56:54
mac007
Re: Installation on Ubuntu 20.04 - Virtual Machine - Solution not working
Perhaps you should try with an other version of Python?
Kenavo
#3 2021-02-07 14:16:00
kathi
I have the exact same output as Markone, see above.
is there a solution please?
Or Markone, did you resolve it?
thanks and regards
kathi
#4 2021-02-10 21:39:05
maybe my solution in post id=25306 also works here?
'sudo apt install python' before the installation of SM2020 with './salome_meca-2020.0.1-1-universal.run' ? I have found, that the old python command is needed during installation.
Give it a try and let me know,
#5 2021-02-11 11:39:03
kathi
yes I confirm. Very strange that python 2 is used for the install and python 3 after for using the soft
many thanks
kathi
