#1 2020-09-14 22:15:36
TamasBalogh
Python equivalent of CA results [SOLVED]
Dear CA users and experts!
I would like to know if there is a general naming convention for the data sets generated to store the code aster simulation results in python?
Simply put, I have a simulation result from DYNA_VIBRA, say dynaRes = DYNA_VIBRA( ... ) , of which I want to have the SIGM_ELNO results for the mesh group "Column", is there an abbreaviated data storing variable that contains this data ? I find data manipulation and post-processing with python easier than with CA specific commands.
Thank you,
Tamas
#2 2020-09-16 22:10:58
Irvise
Re: Python equivalent of CA results [SOLVED]
Hi Tamas,
as far as I know, you can easily output the results of a simulation in table format. If you want to work with python, CA supports outputting the results as a Numpy array (.npy).
Here is the relevant information: u4.81.21 to extract values off a simulation; u4.91.03 to output a table.
Fernando Oleo Blanco
#3 2020-09-20 16:54:29
TamasBalogh
Thank you Fernando for your hints! I've managed to do it with those commands!
#4 2020-09-20 18:30:16
Irvise
Great, I am glad it helped you!
You can mark the thread as [Solved] so that other people may see it as such smile
Fernando
#5 2020-09-20 18:46:36
TamasBalogh
Now, that is something I have been having issues with! I just cannot find the "Mark as SOLVED" or anything similar button! big_smile
Or do I just rename the forum title ?
Tamas
#6 2020-09-20 19:02:13
Irvise
Renaming is (I suppose) the way it is done smile
