#1 2020-09-01 22:13:29
Javier_Podetti
ERROR in beam AFFE_CARA_MECA
Dear all,
First, let me give you some background for my problem: I'm trying to model an excavation using a mesh which was imported from FreeCAD. I have 5 meshes (a solid, 3 shells and a beam) which i turned into a Compound mesh using Salome Meca. As a test run, i'm using only gravity and preventing all 5 "parts" to move using LIAISON='ENCASTRE'.
I've made several runs, in Run_6, I define both the beam and the shell properties in a single AFFE_CARA_ELEM, and I get a program error (both .comm and .mess file are attached to this post)
In Run_7 (.comm and .mess files attached) I define the beam and shell properties in diferent AFFE_CARA_MECA, but i get the following error:
!  User error:        !
   !  One seeks to create a CHAM_ELEM but on certain points, one does not find the component:  COQ_NCOU  !
   !  Field:  Punt        !
   ! .CANBSP
Punt is the name of the beam AFFE_CARA_MECA. This sounds odd since i understood that COQ_NCOU is an error associated with shell elements.
I'd be very helpful if someone could give me some insight regarding this error.
Best regards from Argentina.
Javier
#2 2020-09-01 22:16:38
Javier_Podetti
Re: ERROR in beam AFFE_CARA_MECA
I attach the missing files.
#3 2020-09-03 08:10:11
dezsit
I checked only your comm file (and not the whole study). Two comments:
1) You have to identify in the solution sequence which element characteristics should be used:
eg.:
PP = MECA_STATIQUE(identifier=u'14:1',
                   CARA_ELEM=Horm_Th #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                   CHAM_MATER=MATS,
                   EXCIT=(_F(CHARGE=BC),
                          _F(CHARGE=Grav),
                          _F(CHARGE=BC_Horm)),
2) Since in one solution sequence you can use only one CARA_ELEM, you have to describe all your element characteristic in one AFFE_CARA_ELEM,
As I noticed, the element in GrPuntal_Edges group used in two different AFFE_CARA_ELEM (Horm_TH and Punt), with the same characteristic, as I mentioned both cannot be used in the same solution (and in this case it does not really have any sense, because the properties are the same).
Hope this helps,
dezsit
#4 2020-09-03 13:22:22
Javier_Podetti
Dear dezsit,
Thank you for your help. I did what you suggested and I don't get that error anymore. I get other errors now, but I think I'll manage to sort them out.
Kind regards,
Javier
